Replacing 1990 318 with a 1968 318 in a D150 worth it? #1399383
03/09/13 01:04 AM
03/09/13 01:04 AM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
I have a 1990 D150 318. The plan is to install a mild cam and converter.But the truck has a loud rattle which sounds like a lifter noise. I pulled off the intake and noticed that the lifters are roller which are pricy plus this means I will have a fortune in the cam also and I'm on a budget. I have another 318 from a 1968 barracuda I was pondering over putting in the D150 and was wondering if this would be an easy swap or if anybody has ever done anything like this? And if the whole tbi system would work out on top of the 1968 originally carburated 318? Any info or advice at all with this swap would be greatly appreciated.
Thanks.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: 1967-418] #1399384
03/09/13 01:18 AM
03/09/13 01:18 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
How do you plan on getting around the factory TBI/electronics to run the early 318? Id fix the 90 TBI and dont worry about a cam/ect..
I am truckless..
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: 340SHORTY] #1399385
03/09/13 01:53 AM
03/09/13 01:53 AM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
That's what I was wondering. I was gonna use try the the 1990 tbi intake and carb on the 1968 318. But I was making sure this would work ok or if anyone else tried this and ran into issues.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: 1967-418] #1399386
03/09/13 04:16 AM
03/09/13 04:16 AM
usa
franks lil red Offline
usa
I have a 91 v 8 dak and was thinking of doing the same thing with a 70 318
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: franks lil red] #1399387
03/09/13 11:24 AM
03/09/13 11:24 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
They will work with just swapping parts but why install an engine that the exhaust seats are not really compatible with today's gas & the valves will sink in Besides, why go flat tappet when you already have roller
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: BulletBob] #1399388
03/09/13 11:42 AM
03/09/13 11:42 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
look at the local cl i just sold a magnum 318 complete soup to nut...intake front serp setup harness starter for 250 bucks and was glad to be rid of it.
in a pinch your earlier engine will work just fine with transfer of parts from the later engine...youll be into it for some gaskets and incidentals, if moneys a big issue, your own labor doesnt cost you much so id think your better off having a running truck than one that doesnt
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: pnypwr] #1399389
03/09/13 12:57 PM
03/09/13 12:57 PM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
I pulled these lifters are and I noticed on the top of one of the lifters you can push down on it and it feels kind of soft. Would it be safe just to replace one without replacing all of them?
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: 1967-418] #1399390
03/09/13 01:12 PM
03/09/13 01:12 PM
dogdays Offline
dogdays  Offline
Bullet cams will regrind your stock roller cam for less than $150.
R.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: 1967-418] #1399391
03/09/13 08:13 PM
03/09/13 08:13 PM
IN
ahy Offline
ahy  Offline
IN
Roller cams aren't sensitive to roller and cam lobe match. As long as the cam is in decent shape, its fine to replace a single lifter.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: ahy] #1399392
03/09/13 08:39 PM
03/09/13 08:39 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
A 60s or early 70s 318 won't last long as a daily driver on today's gasoline before you have valve and seat problems. Been there, done that... In the 90s.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: pinkduster] #1399393
03/09/13 10:14 PM
03/09/13 10:14 PM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
Ok. And I already have anyway the lifters out is there anyway I can possibly tell if a lifters bad? Thanks for the help so far
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: 1967-418] #1399394
03/09/13 10:28 PM
03/09/13 10:28 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Did you actually price the lifters? I was thinking that they aren't that expensive. Seems I replaced a few of mine years ago and don't remember them costing that much.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: RalleyA12] #1399395
03/09/13 10:46 PM
03/09/13 10:46 PM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
10.99 a piece. just picked up 2 from autozone. one felt a little soft. not sure if that means anything and one fell in the dirt.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: franks lil red] #1399396
03/10/13 12:35 PM
03/10/13 12:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Gonna have to make motor mounts for this, the 91 dak 318 is the only LA 318 with the bolt holes in the side to bolt up to dak motor mounts, it is a 1 year 1 application engine. Even van and ram 91 318s did not have the bolt hole for the motor mounts.
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: HotRodDave] #1399397
03/10/13 01:28 PM
03/10/13 01:28 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
What do you do for crank sensors and such with an old shortblock?
Sheldon
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: RUNCHARGER] #1399398
03/10/13 02:25 PM
03/10/13 02:25 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Sheldon, I bought a 94 model down in the Arkansas land where they wear no shoes
It had a 340 with Mag top end & the crank sensor urethaned to the rubber dust boot & it was urethaned to the bellhousing
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: BulletBob] #1399399
03/10/13 02:33 PM
03/10/13 02:33 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Easy! Thanks, I was just wondering if there was an easy workaround.
Sheldon
Re: Replacing 1990 318 with a 1968 318 in a D150 worth it? [Re: RUNCHARGER] #1399400
03/10/13 11:50 PM
03/10/13 11:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
No crank sensor till 92 on the 318 and 93 on the 360 wneh they went to magnums. The TBI motors used the distributer for base timing still even though the computer actually controlled the curve.
On the 340 magnum truck the real question is how they bolted the engine in
