Re: Replacing 1990 318 with a 1968 318 in a D150 worth it?
[Re: BulletBob]
#1399388
03/09/13 11:42 AM
03/09/13 11:42 AM
Posts: 4,872 connecticut
pnypwr
connecticut
look at the local cl i just sold a magnum 318 complete soup to nut...intake front serp setup harness starter for 250 bucks and was glad to be rid of it.
in a pinch your earlier engine will work just fine with transfer of parts from the later engine...youll be into it for some gaskets and incidentals, if moneys a big issue, your own labor doesnt cost you much so id think your better off having a running truck than one that doesnt
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: 1967-418]
#1399391
03/09/13 08:13 PM
03/09/13 08:13 PM
Posts: 7,664 IN
ahy
IN
I pulled these lifters are and I noticed on the top of one of the lifters you can push down on it and it feels kind of soft. Would it be safe just to replace one without replacing all of them?
Roller cams aren't sensitive to roller and cam lobe match. As long as the cam is in decent shape, its fine to replace a single lifter.
[Re: RUNCHARGER]
#1399400
03/10/13 11:50 PM
03/10/13 11:50 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
No crank sensor till 92 on the 318 and 93 on the 360 wneh they went to magnums. The TBI motors used the distributer for base timing still even though the computer actually controlled the curve. On the 340 magnum truck the real question is how they bolted the engine in
