Cam selection for 410 ci SB #1396525
03/03/13 10:13 AM
03/03/13 10:13 AM
ont,canada
mopartuner Offline OP
ont,canada
I am going to use a solid flat tappet cam in my new 410 Small block and wanted to know some oppinions.The motor is a pump gas(94 oct) 10.5 comp. engine with ported edelbrocks ,victor intake,850 ultra hp carb,TTI step headers,1.6 rockers.Car is 3000# 904 auto/low 1st,4200 stahl,410 gear ,28 inch tire.Lift? dur? Brand?
410 pump gas solis flat tappet cam 10.95 so far
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396526
03/03/13 11:29 AM
03/03/13 11:29 AM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Maybe this one from comp cams.
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396527
03/03/13 11:41 AM
03/03/13 11:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have pretty much the same combo in a 408. In my 3260# Dart it's ran a best of 6.57 with a Hughes 6064 flat solid on pump 93.
Re: Cam selection for 410 ci SB [Re: krw71ragtop] #1396528
03/03/13 11:42 AM
03/03/13 11:42 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I'm diggin the MP 557 in my 408. Your stall is about right for it. I assume the springs will be spec'd after you decide on a cam?
You might be able to get more power with an ultradyne or something if that's what you're after. The 557 has great manners, nice idle, and the power builds smoothly- no jerk when it gets up on the cam.
Fwiw I started with a comp hft xe275hl- more power down low but bad manners, noisier than the big lash oldschool mp solid, and all finished at 5k with unported eddys, 750dp and hooker comp headers.
Good luck- I'll be watching to see what other folks have to say
Radar
Re: Cam selection for 410 ci SB [Re: radar] #1396529
03/04/13 05:58 PM
03/04/13 05:58 PM
ont,canada
ont,canada
I contacted Crower about a custom cam and there sugestion was a 611/624 lift 264/270 dur on a 108 cl.......said it should make about 550 hp.......opinions?
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396530
03/04/13 06:24 PM
03/04/13 06:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not trying to be a wiseaxx, but Jere STAHL was a header builder. Converters have a STALL speed.
Re: Cam selection for 410 ci SB [Re: topside] #1396531
03/04/13 06:45 PM
03/04/13 06:45 PM
ont,canada
ont,canada
Then what were you trying to be.................I asked what I thought was a good question,lots of guys around here building pump gas strokers............I am out
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396532
03/04/13 06:50 PM
03/04/13 06:50 PM
Guitar Jones Offline
Don't take it personal, there is always one in every crowd. There is still good info here.
Re: Cam selection for 410 ci SB [Re: justinp61] #1396533
03/04/13 06:51 PM
03/04/13 06:51 PM
ont,canada
ont,canada
I have pretty much the same combo in a 408. In my 3260# Dart it's ran a best of 6.57 with a Hughes 6064 flat solid on pump 93. [/quoteThats a good running combo and close to the same came that Crower recomended,cheers
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396534
03/04/13 07:12 PM
03/04/13 07:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Dude, you did ask a good and pertinent question. Just passing the spelling on for what it's worth. I didn't think it was bad form or upsetting to do so.
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396535
03/04/13 07:19 PM
03/04/13 07:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
I had a 390" Stroker
11.3:1
ported edelbrocks
Victor intake
750 holley
Custom Ground Bullet
263/268@.050
.656/.663 lift IIRC
3500# Dart it went 10.75@123 on 92 octane pump gas.
4.10 gear 27" tire
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396536
03/04/13 07:19 PM
03/04/13 07:19 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I'm using the MP 590.
Re: Cam selection for 410 ci SB [Re: topside] #1396537
03/04/13 07:27 PM
03/04/13 07:27 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I have had a few done by, and am very happy with Bullet/Ultradyne Cams.
Re: Cam selection for 410 ci SB [Re: topside] #1396538
03/04/13 07:39 PM
03/04/13 07:39 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
The cam Crower recommended should get you into the 10.20-.30 range I run a Bullet roller 264/268 .636 lift and have gone 9.95 in good air at 2815 lbs. Best of luck
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396539
03/04/13 09:48 PM
03/04/13 09:48 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you have not seen it yet,the latest Mopar Muscle ( May) features an article I wrote testing 8 different camshafts in a stroke small block
Its not an identical build but it will give you an idea how different camshafts affected the engine and may help you make a decision. If I can help at all just ask!
Keith
Re: Cam selection for 410 ci SB [Re: Dunnuck Racing] #1396540
03/04/13 10:27 PM
03/04/13 10:27 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
This one was spec'd by Dwayne Porter for a 416. He spec'd it to be run with full exhaust and a minimum of 10.5 compression.
Com Cams CRS 7262/7263 S 110.0 Valve adjustment: intake= .026 exhaust= .026 Gross lift .577 intake .585 exhaust Duration @ .050 tappet lift intake= 262 exhaust= 266 Valve timing @ .050 intake open 25 BTDC close 57 ABDC Exhaust open 67 BBDC close 19 ATDC These specs are for cam installed @ 106 center line. Duration @ .050 intake 262 exhaust 266 Lobe lift intake .3850 exhaust .3900 lobe separation 110.0.
