Cam selection for 410 ci SB #1396525
03/03/13 10:13 AM
03/03/13 10:13 AM
ont,canada
mopartuner Offline OP
ont,canada
I am going to use a solid flat tappet cam in my new 410 Small block and wanted to know some oppinions.The motor is a pump gas(94 oct) 10.5 comp. engine with ported edelbrocks ,victor intake,850 ultra hp carb,TTI step headers,1.6 rockers.Car is 3000# 904 auto/low 1st,4200 stahl,410 gear ,28 inch tire.Lift? dur? Brand?
410 pump gas solis flat tappet cam 10.95 so far
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396526
03/03/13 11:29 AM
03/03/13 11:29 AM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Maybe this one from comp cams.
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396527
03/03/13 11:41 AM
03/03/13 11:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have pretty much the same combo in a 408. In my 3260# Dart it's ran a best of 6.57 with a Hughes 6064 flat solid on pump 93.
Re: Cam selection for 410 ci SB [Re: krw71ragtop] #1396528
03/03/13 11:42 AM
03/03/13 11:42 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I'm diggin the MP 557 in my 408. Your stall is about right for it. I assume the springs will be spec'd after you decide on a cam?
You might be able to get more power with an ultradyne or something if that's what you're after. The 557 has great manners, nice idle, and the power builds smoothly- no jerk when it gets up on the cam.
Fwiw I started with a comp hft xe275hl- more power down low but bad manners, noisier than the big lash oldschool mp solid, and all finished at 5k with unported eddys, 750dp and hooker comp headers.
Good luck- I'll be watching to see what other folks have to say
Radar
Re: Cam selection for 410 ci SB [Re: radar] #1396529
03/04/13 05:58 PM
03/04/13 05:58 PM
ont,canada
ont,canada
I contacted Crower about a custom cam and there sugestion was a 611/624 lift 264/270 dur on a 108 cl.......said it should make about 550 hp.......opinions?
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396530
03/04/13 06:24 PM
03/04/13 06:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not trying to be a wiseaxx, but Jere STAHL was a header builder. Converters have a STALL speed.
Re: Cam selection for 410 ci SB [Re: topside] #1396531
03/04/13 06:45 PM
03/04/13 06:45 PM
ont,canada
ont,canada
Then what were you trying to be.................I asked what I thought was a good question,lots of guys around here building pump gas strokers............I am out
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396532
03/04/13 06:50 PM
03/04/13 06:50 PM
Guitar Jones Offline
Don't take it personal, there is always one in every crowd. There is still good info here.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Cam selection for 410 ci SB [Re: justinp61] #1396533
03/04/13 06:51 PM
03/04/13 06:51 PM
ont,canada
ont,canada
I have pretty much the same combo in a 408. In my 3260# Dart it's ran a best of 6.57 with a Hughes 6064 flat solid on pump 93. [/quoteThats a good running combo and close to the same came that Crower recomended,cheers
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396534
03/04/13 07:12 PM
03/04/13 07:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Dude, you did ask a good and pertinent question. Just passing the spelling on for what it's worth. I didn't think it was bad form or upsetting to do so.
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396535
03/04/13 07:19 PM
03/04/13 07:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
I had a 390" Stroker
11.3:1
ported edelbrocks
Victor intake
750 holley
Custom Ground Bullet
263/268@.050
.656/.663 lift IIRC
3500# Dart it went 10.75@123 on 92 octane pump gas.
4.10 gear 27" tire
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396536
03/04/13 07:19 PM
03/04/13 07:19 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I'm using the MP 590.
Re: Cam selection for 410 ci SB [Re: topside] #1396537
03/04/13 07:27 PM
03/04/13 07:27 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I have had a few done by, and am very happy with Bullet/Ultradyne Cams.
Re: Cam selection for 410 ci SB [Re: topside] #1396538
03/04/13 07:39 PM
03/04/13 07:39 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
The cam Crower recommended should get you into the 10.20-.30 range I run a Bullet roller 264/268 .636 lift and have gone 9.95 in good air at 2815 lbs. Best of luck
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Cam selection for 410 ci SB [Re: mopartuner] #1396539
03/04/13 09:48 PM
03/04/13 09:48 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If you have not seen it yet,the latest Mopar Muscle ( May) features an article I wrote testing 8 different camshafts in a stroke small block
Its not an identical build but it will give you an idea how different camshafts affected the engine and may help you make a decision. If I can help at all just ask!
Keith
Re: Cam selection for 410 ci SB [Re: Dunnuck Racing] #1396540
03/04/13 10:27 PM
03/04/13 10:27 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
This one was spec'd by Dwayne Porter for a 416. He spec'd it to be run with full exhaust and a minimum of 10.5 compression.
Com Cams CRS 7262/7263 S 110.0 Valve adjustment: intake= .026 exhaust= .026 Gross lift .577 intake .585 exhaust Duration @ .050 tappet lift intake= 262 exhaust= 266 Valve timing @ .050 intake open 25 BTDC close 57 ABDC Exhaust open 67 BBDC close 19 ATDC These specs are for cam installed @ 106 center line. Duration @ .050 intake 262 exhaust 266 Lobe lift intake .3850 exhaust .3900 lobe separation 110.0.
