Cam selection for 410 ci SB
#1396525
03/03/13 10:13 AM
03/03/13 10:13 AM
Posts: 614 ont,canada
mopartuner
ont,canada
I am going to use a solid flat tappet cam in my new 410 Small block and wanted to know some oppinions.The motor is a pump gas(94 oct) 10.5 comp. engine with ported edelbrocks ,victor intake,850 ultra hp carb,TTI step headers,1.6 rockers.Car is 3000# 904 auto/low 1st,4200 stahl,410 gear ,28 inch tire.Lift? dur? Brand?
410 pump gas solis flat tappet cam 10.95 so far
Re: Cam selection for 410 ci SB
[Re: radar]
#1396529
03/04/13 05:58 PM
03/04/13 05:58 PM
mopartuner
ont,canada
I contacted Crower about a custom cam and there sugestion was a 611/624 lift 264/270 dur on a 108 cl.......said it should make about 550 hp.......opinions?
[Re: mopartuner]
#1396532
03/04/13 06:50 PM
03/04/13 06:50 PM
Guitar Jones
Not trying to be a wiseaxx, but Jere STAHL was a header builder. Converters have a STALL speed.
Then what were you trying to be.................I asked what I thought was a good question,lots of guys around here building pump gas strokers............I am out
Don't take it personal, there is always one in every crowd. There is still good info here.
[Re: mopartuner]
#1396535
03/04/13 07:19 PM
03/04/13 07:19 PM
Triple Threat
Renton Washington
I had a 390" Stroker 11.3:1 ported edelbrocks Victor intake 750 holley Custom Ground Bullet 263/268@.050 .656/.663 lift IIRC 3500# Dart it went 10.75@123 on 92 octane pump gas. 4.10 gear 27" tire
[Re: mopartuner]
#1396536
03/04/13 07:19 PM
03/04/13 07:19 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
I'm using the MP 590.
