Re: 440 Dyno Results - My $500 Build [Re: BSB67] #1372069
01/20/13 12:15 AM
01/20/13 12:15 AM
St. Louis, MO
Blues_Cuda Offline OP
St. Louis, MO
The 2295 piston has a 12 cc dome and with a 78 cc head should be way more than 11:1. Maybe more like 12:1
These did not have a 12 cc dome...it was actually a little less than 10.
...and this was far from a zero-deck.
Re: 440 Dyno Results - My $500 Build [Re: BluCuda] #1372070
01/20/13 12:47 AM
01/20/13 12:47 AM
St. Louis, MO
St. Louis, MO
What are the specs of the Ultradyne cam you had and how did it perform on the street and track before it broke?
I don't have the grind # handy at the moment, but the duration @ .050 was in the 250s and it had .588 lift. It was a breeze to drive on the street. Obviously it was far from a smooth, stock idle, but stop and go driving was not an issue. As I stated earlier, everybody has a different idea of what is streetable. My wife never had an issue with it though...never had to be 2 footed & it did not load up on us.
Plenty of power for what it was. The car ran 11.50's in the same exact form it is driven on the street...even with the baby seat in the back. I'll probably buy the same grind again when a 'new' motor goes together. I'm still disappointed the cam was damaged when the old short block signed off.
Re: 440 Dyno Results - My $500 Build [Re: Blues_Cuda] #1372071
01/20/13 02:17 AM
01/20/13 02:17 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Id really like to post some sarcastic comments about how people are always telling us not to use those heavy 6 pack rods and 2295 pistons, and how purple shafts are old antiquated technology, and blah blah blah....
But honestly I am just really glad to see someone using the old school tech and making it work.
Kudos....
Re: 440 Dyno Results - My $500 Build [Re: NTOLERANCE] #1372072
01/20/13 07:22 AM
01/20/13 07:22 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
sign of the times. Moons ago this was a high end build.
Re: 440 Dyno Results - My $500 Build [Re: Blues_Cuda] #1372073
01/20/13 09:33 AM
01/20/13 09:33 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I'm just going buy what the manufacturer says. Apparently you did a down fill. Certainly the devil is in the details. The 2295 will sit about 0.040 below a cleaned-up deck, which is what I used in my estimate. Could be 0.050-ish in an untouched block.
Re: 440 Dyno Results - My $500 Build [Re: BSB67] #1372074
01/20/13 11:10 AM
01/20/13 11:10 AM
maryland
buck440 Offline
buck440  Offline
maryland
sounds alot like my current build except for i got stealth heads. what kinda power do you guy's think she will make with a 509 cam?
Re: 440 Dyno Results - My $500 Build [Re: buck440] #1372075
01/20/13 02:19 PM
01/20/13 02:19 PM
California
mickm Offline
mickm  Offline
California
really impressive! i just did a build from scracth, and it was a bit more than $500!
but it is really cool to see this kind of power for so little cost!
Re: 440 Dyno Results - My $500 Build [Re: buck440] #1372076
01/20/13 02:25 PM
01/20/13 02:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A 509 cam will make good power installed at 102 (no later than 104) depending on if you do some porting to the stealth's you could be from - 30 hp to maybe a few more with the 509.
Re: 440 Dyno Results - My $500 Build [Re: BSB67] #1372077
01/20/13 03:56 PM
01/20/13 03:56 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
If you do the math and assuming the pistons are .045-055 in the hole which is normal for a 2295 piston and even with a 12cc dome, 11 to 1 isn't far off. With a 1009 gasket,assuming .050 in the hole and 78cc head, I get 11.27 to 1.
Re: 440 Dyno Results - My $500 Build [Re: Dodgem] #1372078
01/20/13 10:57 PM
01/20/13 10:57 PM
maryland
buck440 Offline
buck440  Offline
maryland
my stealth's are ported. how does one go about the install at 102? ialso have a team g intake with dominator flange port matched plannin on runnin a 1050.carb that is lol.
Re: 440 Dyno Results - My $500 Build [Re: Blues_Cuda] #1372079
01/20/13 11:13 PM
01/20/13 11:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Here is how it sounds in my wife's Barracuda. Sounds just like the old engine actually.
440 in the Barracuda
Car sounds mean! I love the budget idea a lot............good job. If I wasn`t an et chaser, I`d do a similar deal.
Re: 440 Dyno Results - My $500 Build [Re: buck440] #1372080
01/20/13 11:21 PM
01/20/13 11:21 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
You have to get a cam degree wheel and degree the cam if you want to do it right, or you can just take your chances and get a multi keyway timing chain set and just install it at 6 degrees advanced, I believe the 509 has a 108 intake lobe centerline so 108-6 = 102.
Re: 440 Dyno Results - My $500 Build [Re: NTOLERANCE] #1372081
01/21/13 12:00 PM
01/21/13 12:00 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Kudos....
My car has a LOT of old DC and MP stuff in it.It doesn't matter if the engine has old school parts or the "new and improved"..if it still runs what it's supposed to and the money at the track is the same,then why bother,especially if the stuff on the shelf is gathering dust.
to the OP..VERY nice build,and post how it does when you go to the track.Also look at the UltraDyne 308/613 cam...that cam flat WORKS!!
Nautilus Racing-
Re: 440 Dyno Results - My $500 Build [Re: buck440] #1372082
01/21/13 04:06 PM
01/21/13 04:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well degreeing the cam is a must!!
With ported stealths you will make as much or more than above and run on 91 octane if 10.5 and below.
The 509 if the 108 LSA is designed to be in at 106 but that is too late.
Now you must degree the cam as if the dowel pin in the cam, dowel hole in the top gear, keyway in the bottom gear and key in the crank are off and they are!!!!!!!!!! sometimes a lot. it will be a super dog if retared and they usually are so in at 103 (102 to 104) I would try for 102 from experience, it will be super hot!!
hope this all works well worth the $140 or so to buy your own kit if you don't know anyone to do it for you
If you buy this total kit has video and instructions
http://www.summitracing.com/parts/CCA-4796/
another using @ .050 method think it's a ford by where number 1 is
http://www.youtube.com/watch?v=azLX1pi2oVE&feature=related
plus these to read
http://www.carcraft.com/howto/116_0701_how_to_degree_a_camshaft/
video. I like to do the @ .050 but often do both a little extra advance especially on street or heavy cars is a big plus! depending on the cam.
http://www.youtube.com/watch?v=-VwsbEg7Z4I&feature=related
another one using .50 before and after max lift method (i do them all :-))
http://www.youtube.com/watch?feature=endscreen&v=bcMuttJ9RFc&NR=1
some info! try not to get informatoin overload
http://www.wallaceracing.com/cambasics.htm
Generally in theory they are 0 + 4 and - 4 deg as always a cam should really be degreed in for best performance as they are all over the place with the stacking effect of the crank key, cam key/dowel, bottom gear Keyways and placement of dowel hole or keyway in top gear.
Hear is instructions for a comp cam 3 keyway set
http://static.summitracing.com/global/images/instructions/cca-2100.pdf
I just did a 509 that was 7 deg retarded form spec in straight up position the + 4 postion got it withing .5 deg 106.5 on 106 suggested install it was a 4 speed 4.56 gear so runs great but on an auto i would have liked 102 to 104 for better bottom end.
Degreeing in you cam even if you buy a a kit the peformance is day and night when off a few degrees from optimum
kits
http://www.summitracing.com/parts/pro-66787/overview/
http://www.summitracing.com/parts/cca-4796/overview/
instructions
http://static.summitracing.com/global/images/instructions/pro-66787_camshaftdegreewheelkit.pdf
Re: 440 Dyno Results - My $500 Build [Re: Dodgem] #1372083
01/21/13 04:48 PM
01/21/13 04:48 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Has anyone here ever tried the cam degree method where you use a straight edge, two 17mm deep sockets, and a feeler gauge? Just curious.
Re: 440 Dyno Results - My $500 Build [Re: 67Satty] #1372084
01/21/13 06:53 PM
01/21/13 06:53 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
GREAT post! Love the low/no dollar stuff. Funny I just scored a 30K mile 360, balanced, decked, ported (235-ish cfm) **Correction: Cyl head guy says they went 245...we'll see!** 587-heads, airgap, 236 degree hyd cam from a buddy's brother for $500, less carb. I'll leak it, look at the bearings, touch up the VJ and re-flow the heads and plop in my Dart streeter. With a 10" converter and 3.91's I'm hoping to sneak a 11.90-something from it.
Same friend, several years ago: I gave him $400 for a domed piston, well built 383 shortblock (less cam) that had been 11.20's in his 3400 # car. I had a set of 452 heads laying around (260 @ .600") and another friend had a .613" Ultradyne cam laying around. So, this is what it cost me:
SB - $400
Heads - (IIRC, I had about $400 invested not including my time.)
Cam - Free
Lifters - $70
Pushrods - Free from the shortblock guy
Rockers/Springs - $100 (Isky iron and MP double springs, NIB)
M1 Intake $75 swap meet
1050 Dom $250 swap meet
Cobbled together Mopar lean burn dist - Free
MSD - Free that "didn't work". Sent it to MSD and they fixed it for $40!
Pro Parts headers - $150, plus sandblast time and paint
Converter - "J" $250
Trans - 727 Core, $150 for OH kit, MVB that I had in stock.
$200-300 in misc stuff...
All bolted in a 3000# caged, tubbed, A-Body roller bracket car that I paid $2500 (complete) for.
For just a tad over $4K it went 10.60's @ 125 through bullet muffs.
It was no show car, but I wish I kept it...even though I made a good profit when I sold it...LOL!
Re: 440 Dyno Results - My $500 Build [Re: Blues_Cuda] #1372085
01/22/13 03:29 AM
01/22/13 03:29 AM
Central Cal
XXX440 Offline
XXX440  Offline
Central Cal
Very cool!!..same build in my 64,six pack rods,590 solid..pulls like a freight train now that I fixed some of the halfassed things done to it, and replaced the lapped out old carb that was on it when I traded for it!!
