Page 3 of 3 1 2 3
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364474
01/13/13 02:54 AM
01/13/13 02:54 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Love a good whodunit without the guilt of seeing too much damage
Good luck
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: pittsburghracer] #1364475
01/13/13 08:23 AM
01/13/13 08:23 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
Measure your thrust bearing to see how much wear was done when the convertor thrust-ed forward. All that crap was floating around your oiling system probably taking out the bearings.
if you had a converter baloon check your trust face on your crank. I have a 4150 eagle here we had a converter baloon on. we have a .035 groove in it where the converter pushed the crank forward on the trust. about 1 hours use all up tops.
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364476
01/13/13 02:44 PM
01/13/13 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That much damage to the bearings and I wouldn't be surprised if the crank is going to need to be cut the the next undersize to get it back in spec.
Good luck
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: JohnRR] #1364477
01/13/13 04:02 PM
01/13/13 04:02 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
with regards to engine cleanliness i remove everything that is not part of the casting, chase all threads, deburr any flashing/sharp edges as required. use a high pressure washer and galley brush set along with dish detergent for final wash. it's especially important to use the high pressure washer with a 0° tip for cleaning the water jackets if you're going to grout the block. you can also use acid though i've never personally done this. this is AFTER it has been hot tanked. i spend a LOT of time cleaning parts and when doing a block wear a raincoat and face shield because i really have at it with the pressure washer. there's always the potential for casting sand to be stuck in many places. i have tons of brushes of all sizes and lengths and also have two separate cleaning tanks both of which have filters on them.
my father made it simple to understand when he told me "you can't get an engine too clean"
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: jamesc] #1364478
01/16/13 02:44 AM
01/16/13 02:44 AM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Got a call from the machinist today. Good news! The crank magged good and is straight and true. I'm having him polish the rod journals and do whatever is needed to clean up the mains. Looks like I escaped this without having to replace any "expensive" parts. Still more to come here, but I find myself pretty relieved right now!
Re: Dodged a bullet; vibration found - not good (w/ pics) [Re: StealthWedge67] #1364479
01/16/13 02:45 AM
01/16/13 02:45 AM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Page 3 of 3 1 2 3
