.001" undersize main bearing for 383. Can't find a set! #1336713
11/17/12 09:30 PM
11/17/12 09:30 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
My '71 383 came from the factory with .001" undersized mains. I can't seem to find any .001" under main bearings, anyone make them????
Re: .001" undersize main bearing for 383. Can't find a set! [Re: VITC_GTX] #1336714
11/17/12 09:46 PM
11/17/12 09:46 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Put standards on it. The engine wont know the difference..
I am truckless..
Re: .001" undersize main bearing for 383. Can't find a set! [Re: VITC_GTX] #1336715
11/17/12 10:00 PM
11/17/12 10:00 PM
AndyF Online content
AndyF  Online Content
That is a common problem with the low deck blocks. You can try some different brands to see if you get lucky. Or have the crank ground and start over.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: AndyF] #1336716
11/17/12 10:07 PM
11/17/12 10:07 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
What is the largest clearance I can get away with? This will be a low horse build (~335 hp) in a daily driver.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: VITC_GTX] #1336717
11/17/12 11:22 PM
11/17/12 11:22 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't think the .001" under bearings have been made in decades. a standard bearing would probably yeild a .0035" clearance. too loose for a driver. i'd consider going .010" under.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: lewtot184] #1336718
11/17/12 11:43 PM
11/17/12 11:43 PM
Mock it up with a std set & measure what you get (& post it). A high vol pump MAY help if it's a bit excessive
Re: .001" undersize main bearing for 383. Can't find a set! [Re: VITC_GTX] #1336719
11/18/12 02:43 AM
11/18/12 02:43 AM
I might have some NOS ones. I bought a bunch of factory big block bearings from a dealership that was going out of business a few years ago.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: VITC_GTX] #1336720
11/18/12 03:27 AM
11/18/12 03:27 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
ck the clearance & if to loose send the bearings out to get coated
http://speedtalk.com/
Re: .001" undersize main bearing for 383. Can't find a set! [Re: CSK] #1336721
11/18/12 03:29 AM
11/18/12 03:29 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
try calling Frank Mitchell, he still has tons of Mopar engine parts, he shipped me an NOS piston for my Hemi this Spring..
Re: .001" undersize main bearing for 383. Can't find a set! [Re: sthemi] #1336722
11/18/12 07:10 AM
11/18/12 07:10 AM
SE PA
Yellow Fever Offline
SE PA
Contact King Bearings directly.
http://www.kingbearings.com/contact.php
Re: .001" undersize main bearing for 383. Can't find a set! [Re: Yellow Fever] #1336723
11/18/12 07:19 AM
11/18/12 07:19 AM
SE PA
SE PA
Hmmm,
Main and rod bearing sizes std, .001, .002,
.010, .020, .040, .060
http://www.kanter.com/p24-mon.html
Re: .001" undersize main bearing for 383. Can't find a set! [Re: VITC_GTX] #1336724
11/18/12 05:31 PM
11/18/12 05:31 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I had over four thou clearance on the mains on a street 440 when it was put together over twenty years ago. Has had a lot of street miles along with some passes at the track. No problems.Has 60 psi oil pressure at 1000 rpm and 80 going down the road with a Milodon hi vol pump.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: forphorty] #1336725
11/18/12 08:24 PM
11/18/12 08:24 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Sure, but if he has it apart now, why not just do it right and either cut the crank .010 or locate the .001 bearings? I'd spend the couple extra dollars now so I didn't even have to worry about it later.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: Yellow Fever] #1336726
11/19/12 02:44 AM
11/19/12 02:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Hmmm,
That's a generic listing , there isn't any guarantee they have a .001 oversize set.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: JohnRR] #1336727
11/19/12 11:36 PM
11/19/12 11:36 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: .001" undersize main bearing for 383. Can't find a set! [Re: Joesixpack] #1336728
11/20/12 03:12 PM
11/20/12 03:12 PM
dogdays Offline
dogdays  Offline
Bill Cowger, how goes the parts business? Whaddya have for putting bigblock in a sweptline? How about replacement insulator pads for the stock 318?
R.
Re: .001" undersize main bearing for 383. Can't find a set! [Re: Joesixpack] #1336729
11/20/12 04:11 PM
11/20/12 04:11 PM
JohnRR Offline
JohnRR  Offline
http://www.ebay.com/itm/FED-MOGUL-MS876P...=p2047675.l2557
That is one old set of main bearings ... nice find
Re: .001" undersize main bearing for 383. Can't find a set! [Re: JohnRR] #1336730
11/20/12 10:40 PM
11/20/12 10:40 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Parts business is great....moved into 1300 sq foot warehouse,have branched into antique ignition&electrical parts for all cars*trucks,tractors,1920-1975. Worldwide sales. Sorry dont have anything for BB truck conversion. Lower back problems have made me switch to lightweight parts.....check moparts truck parts section....
