Re: .001" undersize main bearing for 383. Can't find a set!
[Re: VITC_GTX]
#1336714
11/17/12 09:46 PM
11/17/12 09:46 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Put standards on it. The engine wont know the difference..
I am truckless..
[Re: AndyF]
#1336716
11/17/12 10:07 PM
11/17/12 10:07 PM
Posts: 4,931 Tri-Cities, Washington
VITC_GTX
That is a common problem with the low deck blocks. You can try some different brands to see if you get lucky. Or have the crank ground and start over.
What is the largest clearance I can get away with? This will be a low horse build (~335 hp) in a daily driver.
[Re: lewtot184]
#1336718
11/17/12 11:43 PM
11/17/12 11:43 PM
RapidRobert
Mock it up with a std set & measure what you get (& post it). A high vol pump MAY help if it's a bit excessive
[Re: VITC_GTX]
#1336720
11/18/12 03:27 AM
11/18/12 03:27 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
ck the clearance & if to loose send the bearings out to get coated http://speedtalk.com/
[Re: sthemi]
#1336722
11/18/12 07:10 AM
11/18/12 07:10 AM
Posts: 1,083 SE PA
Yellow Fever
SE PA
[Re: VITC_GTX]
#1336724
11/18/12 05:31 PM
11/18/12 05:31 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
I had over four thou clearance on the mains on a street 440 when it was put together over twenty years ago. Has had a lot of street miles along with some passes at the track. No problems.Has 60 psi oil pressure at 1000 rpm and 80 going down the road with a Milodon hi vol pump.
[Re: forphorty]
#1336725
11/18/12 08:24 PM
11/18/12 08:24 PM
DaytonaTurbo
Manitoba, Canada
Sure, but if he has it apart now, why not just do it right and either cut the crank .010 or locate the .001 bearings? I'd spend the couple extra dollars now so I didn't even have to worry about it later.
[Re: Yellow Fever]
#1336726
11/19/12 02:44 AM
11/19/12 02:44 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Hmmm, Main and rod bearing sizes std, .001, .002, .010, .020, .040, .060
http://www.kanter.com/p24-mon.html
That's a generic listing , there isn't any guarantee they have a .001 oversize set.
