Re: W2 Geometry
[Re: Plymouth340]
#1333889
11/11/12 05:15 PM
11/11/12 05:15 PM
Posts: 1,019 Finland
mafo
Finland
back when I still had my w2 motor (rip) , I used a mechanical roller with .760/.738 theoretical lift, thanks to the geometry the actual numbers where much less...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: W2 Geometry
[Re: mafo]
#1333890
11/11/12 05:33 PM
11/11/12 05:33 PM
mafo
Finland
The biggest problem is that to gain runner volume you have to have wide runners and lot of offset on the intake rockers, then you waste a lot of lift in the sideways motion of the pushrod... mine had 1" offset which made it extreme, still managed to go 9.39
Re: W2 Geometry
[Re: mafo]
#1333891
11/11/12 05:47 PM
11/11/12 05:47 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
yes, how much lift do you think you lose on a 720 intake lift w2 motor becaues of the gemotry?
Re: W2 Geometry
[Re: Plymouth340]
#1333892
11/11/12 06:11 PM
11/11/12 06:11 PM
mafo
Finland
Hard to guess, depends on offset we did measure lift but I cant remember the exact numbers but it was more than I expected , I remember we had to measure 2 or 3 times just because it didn t make sense at first we put one dial indicator on the lifter and another on the valve ,that was the moment I understood why they made 48* blocks
Re: W2 Geometry
[Re: Plymouth340]
#1333893
11/11/12 06:35 PM
11/11/12 06:35 PM
Posts: 250 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
how fast is it? spraying it? looks good !!!
50 shot of spray with no tuning did 10.76 @ 128 mph. 1.65 60'. 3800 lbs race weight.
This was the first time I sprayed. Everything stayed together. I will make my way to 150 shot next summer.
Re: W2 Geometry
[Re: LA360]
#1333895
11/12/12 12:50 PM
11/12/12 12:50 PM
Guitar Jones
My W5 has net lift figures of .698/.714 as measured at the retainer.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: W2 Geometry
[Re: Guitar Jones]
#1333896
11/12/12 01:35 PM
11/12/12 01:35 PM
79410aspenrt
Saskatchewan (SK)
What make of cam?
I'm building a 450+ small block. Using my w2's and tunnel ram. 13.1 comp and wondering about what cam to use.
Re: W2 Geometry
[Re: 79410aspenrt]
#1333897
11/12/12 01:48 PM
11/12/12 01:48 PM
Guitar Jones
What make of cam?
It's an older Crane 340 Super Stock roller cam. I'm using 1.6 Harland Sharp rockers on it.
Re: W2 Geometry
[Re: Sb Valiant]
#1333899
11/12/12 09:07 PM
11/12/12 09:07 PM
Posts: 6,142 Melbourne , Australia
LA360
Your engine just isn't going to accelerate well with that converter, I would estimate your engine makes peak torque around the 5000-5500 rpm. Your converter would be quite inefficient also, so you would probably see a reduction in your trap RPM. As anyone will tell you, make one change at a time.
Alan Jones
