W2 Geometry #1333877
11/11/12 01:57 PM
11/11/12 01:57 PM
western PA
Sb Valiant Offline OP
western PA
Has anyone ever heard not to run over a certain lift cam because of the geometry of the w2's pushrods?
Re: W2 Geometry [Re: Sb Valiant] #1333878
11/11/12 02:11 PM
11/11/12 02:11 PM
western PA
western PA
I think I heard something like don't run anymore then a 575 lift because I notice on alot w2 small blocks the ones that run real good have a smaller cam like in the mid 500 range.
Re: W2 Geometry [Re: Sb Valiant] #1333879
11/11/12 02:45 PM
11/11/12 02:45 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i got a 650 roller in my w2 motor....
Re: W2 Geometry [Re: Plymouth340] #1333880
11/11/12 02:48 PM
11/11/12 02:48 PM
western PA
western PA
Thats nice man is that a pro dominator tunnel ram with 2 650's? What's the combo on that motor looks like a high 9 low 10 sec motor!
Re: W2 Geometry [Re: Sb Valiant] #1333881
11/11/12 02:52 PM
11/11/12 02:52 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
yes pro dominator and 2 750s...ran 9.65 w2 motor in my duster
Re: W2 Geometry [Re: Plymouth340] #1333882
11/11/12 03:18 PM
11/11/12 03:18 PM
western PA
western PA
Very nice my friend has a pro dominator tunnel ram that I would like to buy off him. Also has a strip domiantor single plane that I have for sure getting off him. We got a 340 stock bore and stock stroke that we are trying to get run and you just get all kinds of different answers. It has w2 econo heads with 2.08 in valves and 1.60 ex. 13:1 trw pistons with a 606 lift flat tappet cam thats getting replaced because it's unknown to us because it was in the motor when we got it. Has a 8 bolt moldex crank and a M-1 intake with a 750 cfm proform carb and 1 5/8 headers. Trying to get it to run 10's with out going to a full roller because don't have the money. Any suggestions? All car is 2800 lbs with driver and has a 904 tranny with trans brake. 10" 4000 stall converter and we are putting in 4.56 gears. Best so far has been 7.56 in 1/8 with 1.65 60 ft
Re: W2 Geometry [Re: Plymouth340] #1333883
11/11/12 03:19 PM
11/11/12 03:19 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
630 lift solid roller in my w2 362'',
Re: W2 Geometry [Re: 79410aspenrt] #1333884
11/11/12 04:58 PM
11/11/12 04:58 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Last cam we had in a W-2 engine was .668 Intake, 0.704 Exhaust, solid roller.
Bill
Re: W2 Geometry [Re: 79410aspenrt] #1333885
11/11/12 05:03 PM
11/11/12 05:03 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
my w2 motor ran the best with 1000cfm holley and indy intake 14-1 compression 9.57 139.92mph at 2800 lbs...you need bigger header for sure and 8 inch converter,,them small blocks love rpm..
Re: W2 Geometry [Re: Sb Valiant] #1333886
11/11/12 05:04 PM
11/11/12 05:04 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
Get rid of the small tube headers..... go 1 7/8 and give it more carb
Re: W2 Geometry [Re: 79410aspenrt] #1333887
11/11/12 05:05 PM
11/11/12 05:05 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
how fast is it? spraying it? looks good !!!
Re: W2 Geometry [Re: bwhackd34] #1333888
11/11/12 05:07 PM
11/11/12 05:07 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
Re: W2 Geometry [Re: Plymouth340] #1333889
11/11/12 05:15 PM
11/11/12 05:15 PM
Finland
mafo Offline
mafo  Offline
Finland
back when I still had my w2 motor (rip) , I used a mechanical roller with .760/.738 theoretical lift, thanks to the geometry the actual numbers where much less...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: W2 Geometry [Re: mafo] #1333890
11/11/12 05:33 PM
11/11/12 05:33 PM
Finland
mafo Offline
mafo  Offline
Finland
The biggest problem is that to gain runner volume you have to have wide runners and lot of offset on the intake rockers, then you waste a lot of lift in the sideways motion of the pushrod...
mine had 1" offset which made it extreme, still managed to go 9.39
Re: W2 Geometry [Re: mafo] #1333891
11/11/12 05:47 PM
11/11/12 05:47 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
yes, how much lift do you think you lose on a 720 intake lift w2 motor becaues of the gemotry?
Re: W2 Geometry [Re: Plymouth340] #1333892
11/11/12 06:11 PM
11/11/12 06:11 PM
Finland
mafo Offline
mafo  Offline
Finland
Hard to guess, depends on offset
we did measure lift but I cant remember the exact numbers but it was more than I expected , I remember we had to measure 2 or 3 times just because it didn t make sense at first
we put one dial indicator on the lifter and another on the valve ,that was the moment I understood why they made 48* blocks
Re: W2 Geometry [Re: Plymouth340] #1333893
11/11/12 06:35 PM
11/11/12 06:35 PM
Saskatchewan (SK)
Saskatchewan (SK)
50 shot of spray with no tuning did 10.76 @ 128 mph. 1.65 60'. 3800 lbs race weight.
This was the first time I sprayed. Everything stayed together. I will make my way to 150 shot next summer.
Re: W2 Geometry [Re: Sb Valiant] #1333894
11/12/12 06:57 AM
11/12/12 06:57 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Sell the 10" convertor and put a 8" unit with around 5000-5500 of stall speed. That alone will liven your combination up.
Alan Jones
Re: W2 Geometry [Re: LA360] #1333895
11/12/12 12:50 PM
11/12/12 12:50 PM
Guitar Jones Offline
My W5 has net lift figures of .698/.714 as measured at the retainer.
Re: W2 Geometry [Re: Guitar Jones] #1333896
11/12/12 01:35 PM
11/12/12 01:35 PM
Saskatchewan (SK)
Saskatchewan (SK)
What make of cam?
I'm building a 450+ small block. Using my w2's and tunnel ram. 13.1 comp and wondering about what cam to use.
