Re: W2 Geometry
[Re: Plymouth340]
#1333889
11/11/12 05:15 PM
11/11/12 05:15 PM
Posts: 1,019 Finland
mafo
Finland
back when I still had my w2 motor (rip) , I used a mechanical roller with .760/.738 theoretical lift, thanks to the geometry the actual numbers where much less...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: W2 Geometry
[Re: mafo]
#1333890
11/11/12 05:33 PM
11/11/12 05:33 PM
mafo
Finland
The biggest problem is that to gain runner volume you have to have wide runners and lot of offset on the intake rockers, then you waste a lot of lift in the sideways motion of the pushrod... mine had 1" offset which made it extreme, still managed to go 9.39
Re: W2 Geometry
[Re: mafo]
#1333891
11/11/12 05:47 PM
11/11/12 05:47 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
yes, how much lift do you think you lose on a 720 intake lift w2 motor becaues of the gemotry?
Re: W2 Geometry
[Re: Plymouth340]
#1333892
11/11/12 06:11 PM
11/11/12 06:11 PM
mafo
Finland
Hard to guess, depends on offset we did measure lift but I cant remember the exact numbers but it was more than I expected , I remember we had to measure 2 or 3 times just because it didn t make sense at first we put one dial indicator on the lifter and another on the valve ,that was the moment I understood why they made 48* blocks
Re: W2 Geometry
[Re: Plymouth340]
#1333893
11/11/12 06:35 PM
11/11/12 06:35 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
how fast is it? spraying it? looks good !!!
50 shot of spray with no tuning did 10.76 @ 128 mph. 1.65 60'. 3800 lbs race weight.
This was the first time I sprayed. Everything stayed together. I will make my way to 150 shot next summer.
Re: W2 Geometry
[Re: LA360]
#1333895
11/12/12 12:50 PM
11/12/12 12:50 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
My W5 has net lift figures of .698/.714 as measured at the retainer.
Re: W2 Geometry
[Re: Guitar Jones]
#1333896
11/12/12 01:35 PM
11/12/12 01:35 PM
79410aspenrt
Saskatchewan (SK)
What make of cam?
I'm building a 450+ small block. Using my w2's and tunnel ram. 13.1 comp and wondering about what cam to use.
