My W5 has net lift figures of .698/.714 as measured at the retainer.
What make of cam?
I'm building a 450+ small block. Using my w2's and tunnel ram. 13.1 comp and wondering about what cam to use.
It's an older Crane 340 Super Stock roller cam. I'm using 1.6 Harland Sharp rockers on it.
