Best way to attach mufflers to my headers? #1326623
10/26/12 09:01 PM
10/26/12 09:01 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
I have headman headers that are coated without flanges. So what is the best way to attach mufflers? Should I weld them on? Or are the mufflers bands any good?
Re: Best way to attach mufflers to my headers? [Re: Hunted Duck] #1326624
10/26/12 09:08 PM
10/26/12 09:08 PM
Az
Crizila Offline
Crizila  Offline
Az
I use the bands, but I use them only in a temporary situation - to street test drive. They actually seal quite well.
Fastest 300
Re: Best way to attach mufflers to my headers? [Re: Hunted Duck] #1326625
10/26/12 09:09 PM
10/26/12 09:09 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I have used the bands, and they do work, but get the step style and have the pipe expand to go over the collector. Thats what I did, and never had a problem with them coming lose and or falling off..
Re: Best way to attach mufflers to my headers? [Re: 70dusterjohn] #1326626
10/26/12 09:15 PM
10/26/12 09:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Best way to attach mufflers to my headers? [Re: Crizila] #1326627
10/26/12 09:26 PM
10/26/12 09:26 PM
Newark, OH
Newark, OH
Thanks for the info so far. Want to go with a quiet muffler. Any suggestions on a muffler that is quiet?
Re: Best way to attach mufflers to my headers? [Re: Hunted Duck] #1326628
10/26/12 11:11 PM
10/26/12 11:11 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You going to sneak up on the competition
I like my Dynomax 6" round muffs FWIW
Re: Best way to attach mufflers to my headers? [Re: roadhazard] #1326629
10/26/12 11:24 PM
10/26/12 11:24 PM
Newark, OH
Newark, OH
Heck ya
Re: Best way to attach mufflers to my headers? [Re: Hunted Duck] #1326630
10/26/12 11:28 PM
10/26/12 11:28 PM
Magnaflow 3.0 or 3.5 inch inlet and outlet in the 14x7 oval muffs mounted behind the rear end housing exiting at the rear bumper
Re: Best way to attach mufflers to my headers? [Re: Hunted Duck] #1326631
10/26/12 11:30 PM
10/26/12 11:30 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I slid the mufflers over the headers and drilled two holes in each and ran screws into them. Just unscrew the two screws on each muffler to take them off
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Best way to attach mufflers to my headers? [Re: B3422W5] #1326632
10/26/12 11:49 PM
10/26/12 11:49 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Did the same thing but I used pop rivets instead of screws. No crush on the muff.
Re: Best way to attach mufflers to my headers? [Re: John Brown] #1326633
10/27/12 02:57 AM
10/27/12 02:57 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
There is a darn near local to me outfit ( hearttthrob exhaust )that will custom make pipes for you....I plan on having them whip up a slip on pipe for the 3 1/2" collector and weld the muffler to that.
I am puzzling over necking it down to 3 " or not , but plan on about 3 feet of pipe before the muffler with turn downs pointing at each other to try and attract a little less attention on the street.
Something about cancelling frequencies I read once...if I am misguided in my thinking , when you're done laughing , correct me.
Re: Best way to attach mufflers to my headers? [Re: tubtar] #1326634
10/27/12 06:43 AM
10/27/12 06:43 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I used band clamps with tabs welded to the frame to hold the exhaust up
Re: Best way to attach mufflers to my headers? [Re: Cudafied] #1326635
10/27/12 06:59 AM
10/27/12 06:59 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I ran the Magnaflow race mufflers and the Pypes Race Pro mufflers, neither slowed the car down at all and sound nice!
Re: Best way to attach mufflers to my headers? [Re: ProSport] #1326636
10/27/12 10:38 AM
10/27/12 10:38 AM
Newark, OH
Newark, OH
Thanks for the info guys. My collectors are 3 1/2.
