Re: Best way to attach mufflers to my headers?
[Re: Hunted Duck]
#1326624
10/26/12 09:08 PM
10/26/12 09:08 PM
Posts: 7,506 Az
Crizila
Az
I use the bands, but I use them only in a temporary situation - to street test drive. They actually seal quite well.
Fastest 300
[Re: roadhazard]
#1326629
10/26/12 11:24 PM
10/26/12 11:24 PM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
You going to sneak up on the competition
I like my Dynomax 6" round muffs FWIW
Heck ya
[Re: Hunted Duck]
#1326631
10/26/12 11:30 PM
10/26/12 11:30 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I slid the mufflers over the headers and drilled two holes in each and ran screws into them. Just unscrew the two screws on each muffler to take them off
[Re: B3422W5]
#1326632
10/26/12 11:49 PM
10/26/12 11:49 PM
Posts: 1,845 South Bend
John Brown
South Bend
Did the same thing but I used pop rivets instead of screws. No crush on the muff.
[Re: John Brown]
#1326633
10/27/12 02:57 AM
10/27/12 02:57 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
There is a darn near local to me outfit ( hearttthrob exhaust )that will custom make pipes for you....I plan on having them whip up a slip on pipe for the 3 1/2" collector and weld the muffler to that. I am puzzling over necking it down to 3 " or not , but plan on about 3 feet of pipe before the muffler with turn downs pointing at each other to try and attract a little less attention on the street. Something about cancelling frequencies I read once...if I am misguided in my thinking , when you're done laughing , correct me.
[Re: Cudafied]
#1326635
10/27/12 06:59 AM
10/27/12 06:59 AM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
I ran the Magnaflow race mufflers and the Pypes Race Pro mufflers, neither slowed the car down at all and sound nice!
