Re: Best way to attach mufflers to my headers?
[Re: Hunted Duck]
#1326624
10/26/12 09:08 PM
10/26/12 09:08 PM
Posts: 7,506 Az
Crizila
Az
I use the bands, but I use them only in a temporary situation - to street test drive. They actually seal quite well.
Fastest 300
[Re: roadhazard]
#1326629
10/26/12 11:24 PM
10/26/12 11:24 PM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
You going to sneak up on the competition
I like my Dynomax 6" round muffs FWIW
Heck ya
[Re: Hunted Duck]
#1326631
10/26/12 11:30 PM
10/26/12 11:30 PM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
I slid the mufflers over the headers and drilled two holes in each and ran screws into them. Just unscrew the two screws on each muffler to take them off
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1326632
10/26/12 11:49 PM
10/26/12 11:49 PM
Posts: 1,834 South Bend
John Brown
South Bend
Did the same thing but I used pop rivets instead of screws. No crush on the muff.
[Re: John Brown]
#1326633
10/27/12 02:57 AM
10/27/12 02:57 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
There is a darn near local to me outfit ( hearttthrob exhaust )that will custom make pipes for you....I plan on having them whip up a slip on pipe for the 3 1/2" collector and weld the muffler to that. I am puzzling over necking it down to 3 " or not , but plan on about 3 feet of pipe before the muffler with turn downs pointing at each other to try and attract a little less attention on the street. Something about cancelling frequencies I read once...if I am misguided in my thinking , when you're done laughing , correct me.
[Re: Cudafied]
#1326635
10/27/12 06:59 AM
10/27/12 06:59 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I ran the Magnaflow race mufflers and the Pypes Race Pro mufflers, neither slowed the car down at all and sound nice!
