Re: Factory hose clamps any tips/tricks to installing them?
[Re: NV69B7RR]
#1311047
09/26/12 02:07 PM
09/26/12 02:07 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Get a better set of pliers. You won't regret having them.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Challenger 1]
#1311053
09/26/12 08:34 PM
09/26/12 08:34 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This one is a Blue Point from Snap On. Blue point is there afordable line of tools and I own a bunch of Blue Point, better than Craftsman.
Almost identical to 40yr. old K&D and still the easiest to use.
[Re: Southern Wolf]
#1311055
09/26/12 10:29 PM
09/26/12 10:29 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I have the Snap On ones which are easier on the hands, but there are several types out there. IIRC I believe there are two sizes available and they "slip" to go bigger or smaller. I don't have them here to look for myself. My next purchase is the LTI LT998 http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=LTILT-998But I am not sure if it's for Corbin Clamps
Common sense is a flower that does not grow in everybody's garden
[Re: 1_WILD_RT]
#1311057
09/27/12 07:56 AM
09/27/12 07:56 AM
Posts: 21,489 It's a dry heat
gtx6970
It's a dry heat
we think alike. lock on mine was gone a LOOOOOOONG time ago
I've had the KD ones for 30+ years, cut the lock off early on cause it's more aggravating than useful..
[Re: gtx6970]
#1311058
09/27/12 09:07 AM
09/27/12 09:07 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Have had my KD's forever
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: sixpaktoogo]
#1311060
09/27/12 01:19 PM
09/27/12 01:19 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
...(4) Use a light coat of silicon inside the hose.
Hope this helps,
Dan
Silicon helps a lot.
Spring ring clamps are designed for a particular hose thickness, ID, and rubber. Aftermarker/current stuff does not always have those same attributes 100.00%.
Also the 40 year old water necks/outlets we try to save and re-use often have corrosion and pits around them, making them tougher to seal.
