Factory hose clamps any tips/tricks to installing them? #1311046
09/26/12 02:00 PM
09/26/12 02:00 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
As the title says,anybody have some insight to making this job easier, especially on the radiator hoses? I bought the pliers but they dont go big enough for the large clamps. Anybody ever modify a set of channellock pliers to work for this? Any help would be appreciated.
Re: Factory hose clamps any tips/tricks to installing them? [Re: NV69B7RR] #1311047
09/26/12 02:07 PM
09/26/12 02:07 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Get a better set of pliers. You won't regret having them.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Factory hose clamps any tips/tricks to installing them? [Re: NV69B7RR] #1311048
09/26/12 02:28 PM
09/26/12 02:28 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree, get some proper corbin clamp pliers, NAPA should have some. Take a clamp with you when shopping
Re: Factory hose clamps any tips/tricks to installing them? [Re: NV69B7RR] #1311049
09/26/12 02:32 PM
09/26/12 02:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This one is a Blue Point from Snap On. Blue point is there afordable line of tools and I own a bunch of Blue Point, better than Craftsman.
Re: Factory hose clamps any tips/tricks to installing them? [Re: NV69B7RR] #1311050
09/26/12 04:47 PM
09/26/12 04:47 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
right tools make it SO much easier.
as far as tips ?
Yes, don't over extend them and they will seal SO much better
Re: Factory hose clamps any tips/tricks to installing them? [Re: NV69B7RR] #1311051
09/26/12 06:35 PM
09/26/12 06:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Got a pair of slip-joint pliers notched for 'Corbin's...
Made by S&K...Notched for a 'straight-shot', or 90 degrees...
Had 'em since these cars came from the factory with these clamps...
Re: Factory hose clamps any tips/tricks to installing them? [Re: RSNOMO] #1311052
09/26/12 07:10 PM
09/26/12 07:10 PM
dart1962_440 Offline
I have a couple types.
My K-D 429's are newer and my Sears 45392 are vintage and look like regular pliers with the top portion made for the clamps.
There looks to be quite a few on ebay under Vintage Hose Clamp Pliers.
I prefer the Sears one, but both get the job done.
Re: Factory hose clamps any tips/tricks to installing them? [Re: Challenger 1] #1311053
09/26/12 08:34 PM
09/26/12 08:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Almost identical to 40yr. old K&D and still the easiest to use.
Re: Factory hose clamps any tips/tricks to installing them? [Re: 62maxwgn] #1311054
09/26/12 09:11 PM
09/26/12 09:11 PM
SC
Southern Wolf Offline
SC
I bought China made pliers from Advance Auto. They did not last long enought to completely install 1 clamp. Do not buy the junk.
Re: Factory hose clamps any tips/tricks to installing them? [Re: Southern Wolf] #1311055
09/26/12 10:29 PM
09/26/12 10:29 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I have the Snap On ones which are easier on the hands, but there are several types out there. IIRC I believe there are two sizes available and they "slip" to go bigger or smaller. I don't have them here to look for myself.
My next purchase is the LTI LT998
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=LTILT-998
But I am not sure if it's for Corbin Clamps
Common sense is a flower that does not grow in everybody's garden
Re: Factory hose clamps any tips/tricks to installing them? [Re: 62maxwgn] #1311056
09/27/12 12:37 AM
09/27/12 12:37 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've had the KD ones for 30+ years, cut the lock off early on cause it's more aggravating than useful..
Re: Factory hose clamps any tips/tricks to installing them? [Re: 1_WILD_RT] #1311057
09/27/12 07:56 AM
09/27/12 07:56 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
we think alike. lock on mine was gone a LOOOOOOONG time ago
Re: Factory hose clamps any tips/tricks to installing them? [Re: gtx6970] #1311058
09/27/12 09:07 AM
09/27/12 09:07 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Have had my KD's forever
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Factory hose clamps any tips/tricks to installing them? [Re: moparmarks] #1311059
09/27/12 10:56 AM
09/27/12 10:56 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
After installing many factory hose clamps, here's my advise:
(1) Use the good pliers as stated.
(2) Use only quality clamps. There are a few manufactures of them. They need to be "egg shape" before you expand them. If they are "round", do not use them. I have found Frank Badalson has the best clamps.
(3) Expand the clamp only as far as you needed to get it over the hose - never over-expand!
(4) Use a light coat of silicon inside the hose.
Hope this helps,
Dan
Re: Factory hose clamps any tips/tricks to installing them? [Re: sixpaktoogo] #1311060
09/27/12 01:19 PM
09/27/12 01:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
...(4) Use a light coat of silicon inside the hose.
Hope this helps,
Dan
Silicon helps a lot.
Spring ring clamps are designed for a particular hose thickness, ID, and rubber. Aftermarker/current stuff does not always have those same attributes 100.00%.
Also the 40 year old water necks/outlets we try to save and re-use often have corrosion and pits around them, making them tougher to seal.
