Re: Ever have problems with your "kill switch"?
[Re: Mr. T]
#1309471
09/23/12 08:32 PM
09/23/12 08:32 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We had the cheaper Moroso in the car for years and had picked up a misfire or starting problem, not sure which. Replaced stuff and couldn't really get it fixed. For some reason, I decided to look at the switch. Checked it with an ohm meter and it was showing more than a couple tenths of resistance. Took it apart and the contacts were burnt. Replaced it with the more expensive Moroso piece (silver contacts). Never used the cheapy in my or anyone elses car again. Don't remember if it fixed the problem, but I know that switch was bad
[Re: CMcAllister]
#1309472
09/23/12 08:36 PM
09/23/12 08:36 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I had A loose plate inside a battery, that would cause a miss and/or momentarily shut the car off. I chased my tail for weeks to find it.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Mr. T]
#1309473
09/23/12 08:40 PM
09/23/12 08:40 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
What it the amp rating on your switch? If you have the standard 20a moroso switch it will cause problems.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Mr. T]
#1309477
09/23/12 09:37 PM
09/23/12 09:37 PM
Dap
Staten Island N.Y.
The switch I had in my car was made by cole hersee and was the 20amp switch. I had some intermittent electrical problems and replaced the switch with the 300 amp switch from jegs. The car immediately dropped 2/10ths and gained 4 mph.
