Ever have problems with your "kill switch"? #1309470
09/23/12 08:13 PM
09/23/12 08:13 PM
Mississippi
Mr. T Offline OP
Mr. T  Offline OP
Mississippi
Mine is located in the back bumper. We have been having a electrical gremlin problem the last few weeks. Everything seems to be fine, until you get into the water box and start doing the burnout. Suddenly the engine has a severe misfire. It usually only happens every third or fourth pass. Once you shut the engine off, everything goes back to normal.
I was wondering if anybody else has ever had this experience? And how do you know when the "kill switch" needs to be replaced?
Re: Ever have problems with your "kill switch"? [Re: Mr. T] #1309471
09/23/12 08:32 PM
09/23/12 08:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
We had the cheaper Moroso in the car for years and had picked up a misfire or starting problem, not sure which. Replaced stuff and couldn't really get it fixed. For some reason, I decided to look at the switch. Checked it with an ohm meter and it was showing more than a couple tenths of resistance. Took it apart and the contacts were burnt. Replaced it with the more expensive Moroso piece (silver contacts). Never used the cheapy in my or anyone elses car again. Don't remember if it fixed the problem, but I know that switch was bad
Re: Ever have problems with your "kill switch"? [Re: CMcAllister] #1309472
09/23/12 08:36 PM
09/23/12 08:36 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I had A loose plate inside a battery, that would cause a miss and/or momentarily shut the car off. I chased my tail for weeks to find it.
Joe
Without Data, you’re just another guy with an opinion.
Re: Ever have problems with your "kill switch"? [Re: Mr. T] #1309473
09/23/12 08:40 PM
09/23/12 08:40 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
What it the amp rating on your switch? If you have the standard 20a moroso switch it will cause problems.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Ever have problems with your "kill switch"? [Re: Dap] #1309474
09/23/12 08:50 PM
09/23/12 08:50 PM
Mississippi
Mr. T Offline OP
Mr. T  Offline OP
Mississippi
I don't know the amp rating or the brand(sorry). The switch has probably been on the car around 10 years.
Re: Ever have problems with your "kill switch"? [Re: Mr. T] #1309475
09/23/12 08:57 PM
09/23/12 08:57 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
This is the one I have but I need to replace it since it got bent. http://www.summitracing.com/parts/MOR-74101/
Re: Ever have problems with your "kill switch"? [Re: MPerry] #1309476
09/23/12 09:31 PM
09/23/12 09:31 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Yes Tim, they do go bad. Replace it if you have any doubts about it. Also check the ground circuit carefully.
Brian Dunnigan
Re: Ever have problems with your "kill switch"? [Re: Mr. T] #1309477
09/23/12 09:37 PM
09/23/12 09:37 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
The switch I had in my car was made by cole hersee and was the 20amp switch. I had some intermittent electrical problems and replaced the switch with the 300 amp switch from jegs. The car immediately dropped 2/10ths and gained 4 mph.
PRH446
