Page 4 of 6 1 2 3 4 5 6
Re: Another Whats the HP [Re: MR_P_BODY] #1284959
08/18/12 09:54 AM
08/18/12 09:54 AM
tboomer Online work
tboomer  Online Work
Wow!! Sorry to read this,Mike! But if anyone can figure it out,I know it will be you!! Hang in there buddy!
Re: Another Whats the HP [Re: tboomer] #1284960
08/18/12 10:08 AM
08/18/12 10:08 AM
MR_P_BODY Offline OP
Thanks Ted.... I'll get there but for being a cheapo
engine build this thing sure is EATING up money...
I think I'll have to name this engine(I dont name
engines) but this one deserves one... it'll be called
"THE BIT(H".... all it wants to do is take my money
Re: Another Whats the HP [Re: MR_P_BODY] #1284961
08/18/12 10:15 AM
08/18/12 10:15 AM
tboomer Online work
tboomer  Online Work
Nothing is cheap anymore!! And that is the reason I have parked mine. It would be fun to have it licensed and drive on the street but it has too much missing to have the DOT look it over...
Re: Another Whats the HP [Re: MR_P_BODY] #1284962
08/18/12 11:41 AM
08/18/12 11:41 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I have seen debris in between the parts of the pan where the bottom is welded on, you can take a small hammer and bump on it and watch the junk come out. I put them in the parts washer and tap while the fluid is running in it.
Re: Another Whats the HP [Re: SB412DUSTER] #1284963
08/18/12 11:55 AM
08/18/12 11:55 AM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
Yeah that happened to me on a charlies pan, I about died when I pulled the pan, but it was just as you described, and I only noticed it when I was useing a power washer on it, the banging on the ground made it come ot in chunks. Kinda wierd...
Re: Another Whats the HP [Re: SB412DUSTER] #1284964
08/18/12 12:05 PM
08/18/12 12:05 PM
I built the pan I'm using but its steel.. and yeah I
made sure it was clean in any overlaps
Re: Another Whats the HP [Re: SB412DUSTER] #1284965
08/18/12 12:15 PM
08/18/12 12:15 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If you run a oil filter with a bypass that can be why the trash went past the filter, You said some of the bores were scuffed...That would drop torque fast and lead to ring sealing problems... Hang in there Mike its just W5 voodoo
Re: Another Whats the HP [Re: emarine01] #1284966
08/18/12 12:19 PM
08/18/12 12:19 PM
The one cyl is scuffed enough that I'm gonna have it
sleeved the other couple will be honed.... its just
money.... spend it like ya got it
Re: Another Whats the HP [Re: MR_P_BODY] #1284967
08/18/12 12:33 PM
08/18/12 12:33 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Somethings up with that 340 block.... 2nd go around with bore problems might want to sonic it before the sleeve
Re: Another Whats the HP [Re: MR_P_BODY] #1284968
08/18/12 02:07 PM
08/18/12 02:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
It sounds like your piston to bore clearences might not be loose enough, and the pistons are growing trying to sieze itself into the bores.
Or it may be yet another cause, maybe a spun cam bearing starting to bind. Keep on checking it out.
Re: Another Whats the HP [Re: Sport440] #1284969
08/18/12 04:05 PM
08/18/12 04:05 PM
Actually its .002 oversize on the bore ... its not
a cam bearing... already looked and they were fine
and the cam spins nice and free
Re: Another Whats the HP [Re: emarine01] #1284970
08/18/12 04:12 PM
08/18/12 04:12 PM
I know I had it sonic checked before but with all the
340 blocks I have I dont recall on this one but thats
a good idea to have it done again... but I dont think
its a bore problem... just debris got in there
Re: Another Whats the HP [Re: MR_P_BODY] #1284971
08/18/12 04:46 PM
08/18/12 04:46 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mike.... Not wantin to be a pain , just kickin some stuff around, Bock filled or wet? Whats the side clearance? Whos piston, Honed with torque plate? Type of piston coating, Shop temp when measuring vs assembly..... The bores and hone should have been like new both times from the amount of run time, Something's not happy in the bores.
Re: Another Whats the HP [Re: emarine01] #1284972
08/18/12 05:10 PM
08/18/12 05:10 PM
No problem.... its a wet block, bores are .002 larger
than the piston manufacturers spec (Diamond) due to
honing... the first time the oil rings almost dropped
through(about 6# pull) so they were too small for the
bore but I tried it anyways... I had a bore of 4.075
instead of 4.070 and I ordered everything for a 4.070
bore(thats what I thought it was without measuring it)
so this time I had it honed to 4.077 and the rings
are 4.080 non file fit which still gave me material
to file fit them..... I had the pistons coated to
make up the difference but they are .001 smaller than
what I was hoping for... temps were very comparable...
within 10*
Re: Another Whats the HP [Re: MR_P_BODY] #1284973
08/18/12 06:17 PM
08/18/12 06:17 PM
Delray beach, Florida
P
Performance Only Offline
P
within 10*
are you saying the pistons are for a 4.070 bore but the bore is actually 4.077?
machine shop owner and engine builder
Re: Another Whats the HP [Re: Performance Only] #1284974
08/18/12 06:33 PM
08/18/12 06:33 PM
within 10*
They were originally for a 4.070 bore but I had
them coated to make up the difference... this thing
was a screw up on my part from the moment I ordered
the pistons... I measured 2 of my 3 blocks for bore
and I assumed the third was a 4.070 also with just
a quick measurement which it wasnt 4.070 so when I
grabbed that block it was a shorter deck height and
I ordered the pistons to that shorter deck height....
I know I can have the coating removed and use another
block but I would have to see if the cam exposes the
oil supply hole in the lifter
Re: Another Whats the HP [Re: MR_P_BODY] #1284975
08/18/12 06:44 PM
08/18/12 06:44 PM
P
P
within 10*
there's no coating for pistons other than hard anodize that can make up that size difference. those pistons are made with at least .0045 clearance in them so they would measure 4.0655, that leaves you .0115 piston to wall minus .001-.002 spray on moly coating. the moly coating is sacrificial and won't stay there for very long. i think that's way too much clearance. it may be time to just hone it to 4.08 and put the right size pistons in it, if the block will go that far. most factory blocks will be paper thin at that bore size.
Re: Another Whats the HP [Re: Performance Only] #1284976
08/18/12 06:53 PM
08/18/12 06:53 PM
Like I said I can go with another block which is 4.070
and have the coating removed but it will need to be
decked to my set up(rod, piston, stroke combo)
Re: Another Whats the HP [Re: Performance Only] #1284977
08/18/12 06:59 PM
08/18/12 06:59 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I had this same problem when I tore down my old motor and ended up doing a complete new motor/block/everything.. So there is merit in what you're saying..
But if this was the case with Mikes build.. where did the aluminum come from?
Re: Another Whats the HP [Re: Jeepmon] #1284978
08/18/12 07:13 PM
08/18/12 07:13 PM
P
P
i'd say only Mike knows for sure. if the engine is completely torn down there's likely evidence of where it came from. either something was coming apart or it wasn't cleaned properly before assembly. there's really no other way to say it. i'm not trying to be harsh, but what other possibilities come to mind? i know i'd like to see some pictures of the piston skirts as well as all the bearings lined up in a row. maybe he'll post some pictures.
