Re: Another Whats the HP
[Re: tboomer]
#1284960
08/18/12 10:08 AM
08/18/12 10:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Wow!! Sorry to read this,Mike! But if anyone can figure it out,I know it will be you!! Hang in there buddy!
Thanks Ted.... I'll get there but for being a cheapo engine build this thing sure is EATING up money... I think I'll have to name this engine(I dont name engines) but this one deserves one... it'll be called "THE BIT(H".... all it wants to do is take my money ![](/ubbthreads/images/graemlins/wave.gif)
[Re: emarine01]
#1284966
08/18/12 12:19 PM
08/18/12 12:19 PM
MR_P_BODY
If you run a oil filter with a bypass that can be why the trash went past the filter, You said some of the bores were scuffed...That would drop torque fast and lead to ring sealing problems... Hang in there Mike its just W5 voodoo
The one cyl is scuffed enough that I'm gonna have it sleeved the other couple will be honed.... its just money.... spend it like ya got it ![](/ubbthreads/images/graemlins/flame.gif) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284968
08/18/12 02:07 PM
08/18/12 02:07 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
It sounds like your piston to bore clearences might not be loose enough, and the pistons are growing trying to sieze itself into the bores.
Or it may be yet another cause, maybe a spun cam bearing starting to bind. Keep on checking it out. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Sport440]
#1284969
08/18/12 04:05 PM
08/18/12 04:05 PM
MR_P_BODY
Actually its .002 oversize on the bore ... its not a cam bearing... already looked and they were fine and the cam spins nice and free ![](/ubbthreads/images/graemlins/wave.gif)
[Re: emarine01]
#1284970
08/18/12 04:12 PM
08/18/12 04:12 PM
MR_P_BODY
Somethings up with that 340 block.... 2nd go around with bore problems might want to sonic it before the sleeve
I know I had it sonic checked before but with all the 340 blocks I have I dont recall on this one but thats a good idea to have it done again... but I dont think its a bore problem... just debris got in there ![](/ubbthreads/images/graemlins/wave.gif)
[Re: emarine01]
#1284972
08/18/12 05:10 PM
08/18/12 05:10 PM
MR_P_BODY
Mike.... Not wantin to be a pain , just kickin some stuff around, Bock filled or wet? Whats the side clearance? Whos piston, Honed with torque plate? Type of piston coating, Shop temp when measuring vs assembly..... The bores and hone should have been like new both times from the amount of run time, Something's not happy in the bores.
No problem.... its a wet block, bores are .002 larger than the piston manufacturers spec (Diamond) due to honing... the first time the oil rings almost dropped through(about 6# pull) so they were too small for the bore but I tried it anyways... I had a bore of 4.075 instead of 4.070 and I ordered everything for a 4.070 bore(thats what I thought it was without measuring it) so this time I had it honed to 4.077 and the rings are 4.080 non file fit which still gave me material to file fit them..... I had the pistons coated to make up the difference but they are .001 smaller than what I was hoping for... temps were very comparable... within 10* ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284973
08/18/12 06:17 PM
08/18/12 06:17 PM
Posts: 2,091 Delray beach, Florida
Performance Only
are you saying the pistons are for a 4.070 bore but the bore is actually 4.077?
machine shop owner and engine builder
[Re: Performance Only]
#1284974
08/18/12 06:33 PM
08/18/12 06:33 PM
MR_P_BODY
They were originally for a 4.070 bore but I had them coated to make up the difference... this thing was a screw up on my part from the moment I ordered the pistons... I measured 2 of my 3 blocks for bore and I assumed the third was a 4.070 also with just a quick measurement which it wasnt 4.070 so when I grabbed that block it was a shorter deck height and I ordered the pistons to that shorter deck height.... I know I can have the coating removed and use another block but I would have to see if the cam exposes the oil supply hole in the lifter ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1284975
08/18/12 06:44 PM
08/18/12 06:44 PM
Performance Only
there's no coating for pistons other than hard anodize that can make up that size difference. those pistons are made with at least .0045 clearance in them so they would measure 4.0655, that leaves you .0115 piston to wall minus .001-.002 spray on moly coating. the moly coating is sacrificial and won't stay there for very long. i think that's way too much clearance. it may be time to just hone it to 4.08 and put the right size pistons in it, if the block will go that far. most factory blocks will be paper thin at that bore size.
#1284977
08/18/12 06:59 PM
08/18/12 06:59 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I had this same problem when I tore down my old motor and ended up doing a complete new motor/block/everything.. So there is merit in what you're saying..
But if this was the case with Mikes build.. where did the aluminum come from?
