Page 2 of 4 1 2 3 4
Re: Check out this video...tire separating from the wheel [Re: WheelsUp73] #1272461
07/23/12 11:14 PM
07/23/12 11:14 PM
no mans land
racerbychoice Offline
no mans land
Here is my friends car. He has a big tire on the car but is still peels back from the bead at high speed. Bead locks are required for cars 200 mph or faster.
Screws will hold just fine.
http://youtu.be/Mq74hLBlZxA
there are plenty of damaged, wrecked small tire cars and current information that would prove that 15-yr old 200-mph theory dead wrong. the OP is dead accurate with what he posted.
dj
Re: Check out this video...tire separating from the wheel [Re: racerbychoice] #1272462
07/23/12 11:49 PM
07/23/12 11:49 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I lost a 17x34.5 off of a 16" wide wheel on my altered but never lost a true 10.5 off my 12" wide wheel.....I know in this picture i have bead locks but the car has been its fastest with regular wheels.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Check out this video...tire separating from the wheel [Re: racerbychoice] #1272463
07/24/12 12:13 AM
07/24/12 12:13 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
dj
Its not a myth, is an NHRA rule. So what did all the fast cars do before beadlocks? We raced Comp Eliminator in the 80s and there were no bead locks. We all ran rim screws.
Re: Check out this video...tire separating from the wheel [Re: WheelsUp73] #1272464
07/24/12 12:41 AM
07/24/12 12:41 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
dj
we used to run tubes in the 15" wheels and liners in the 16" stuff till we got weight concious.
Re: Check out this video...tire separating from the wheel [Re: bigtimeauto] #1272465
07/24/12 01:04 AM
07/24/12 01:04 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So the bead lock rim is slower in ET than a screwed rim ? why is that?
Re: Check out this video...tire separating from the wheel [Re: Crizila] #1272466
07/24/12 01:13 AM
07/24/12 01:13 AM
ScatPackNick Offline
the wheel is to wide for the tire...
the tread should be equal or a bit wider that the rim width...tires grow with speed and having tall series sidewalls...there's a reason for bead locks
Yep!!
+1
Re: Check out this video...tire separating from the wheel [Re: rowin4] #1272467
07/24/12 01:13 AM
07/24/12 01:13 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
20lbs heavier, but look cool as [Edited by Moparts - Family Friendly Site - Keep it clean] and easier to change tires.
Re: Check out this video...tire separating from the wheel [Re: bigtimeauto] #1272468
07/24/12 02:57 PM
07/24/12 02:57 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Pretty common practice with the true 10.5 and 8.5 stuff to run a wheel widerthan the tire tread width. I have NEVER seen it as an issue. Our tires are always installed BY the manufacter at the track. In fact M/T suggests a larger size wheel to increase the footprint. Some folks just dont get it.
Re: Check out this video...tire separating from the wheel [Re: WheelsUp73] #1272469
07/24/12 06:29 PM
07/24/12 06:29 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I know some TAFC's that run Hoosiers, have no bead
locks. Not sure what they use to keep the
tire on the rim.
Snap your neck, mega G-force launch, is all I want!
Re: Check out this video...tire separating from the wheel [Re: BDS871Cuda] #1272470
07/24/12 06:49 PM
07/24/12 06:49 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
tire on the rim.
they use inner liners, here is some reading material on wheels http://www.dragzine.com/tech-stories/wheels-tires/the-411-on-drag-racing-wheel-technology/
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Check out this video...tire separating from the wheel [Re: bigtimeauto] #1272471
07/24/12 07:33 PM
07/24/12 07:33 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
Bob, ur exactly right, they do look cool. And Charlie has beadlocks, and said the same thing, they are SLOW!
Al, most of our slicks probably do the same thing on a wheel the size of the tread or bigger, we just never saw it,lol. Hense the 20 rim screws per side on his wheels!
It's a bigblock with a torque flight!!!
Re: Check out this video...tire separating from the wheel [Re: Plumb Wired] #1272472
07/24/12 07:45 PM
07/24/12 07:45 PM
Az
Crizila Offline
Crizila  Offline
Az
tire on the rim.
Great article. Thanks. Only thing it doesn't really address is tire to rim width. Does a great job explaining the different styles/ methods of tire to rim attachments, proper usage and limitations.
Fastest 300
Re: Check out this video...tire separating from the wheel [Re: Al_Alguire] #1272473
07/24/12 08:22 PM
07/24/12 08:22 PM
Heaven
EvilB1Dart Offline OP
Heaven
X2....
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272474
07/24/12 09:05 PM
07/24/12 09:05 PM
Az
Crizila Offline
Crizila  Offline
Az
X2....
and your definition of larger size is....... and is it outside the tire manufacturers suggested ( ???? ) minimum / maximum rim width for that tire??? Ya, I don't get it, but I'm open for a valid explaination on just how a wider rim increases a tire foot print. Guess I'm just missing - something .
Fastest 300
Re: Check out this video...tire separating from the wheel [Re: Crizila] #1272475
07/25/12 12:02 AM
07/25/12 12:02 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Not like anything I'll ever own would be fast enough to have this issue, but unless I were changing screws every pass I wouldn't trust that setup. Fatigue plays a big role in how long those screws will hold up. One or two shear off and you get enough vibration, more are likely to follow Plus beadlocks look awesome
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272476
07/25/12 03:26 PM
07/25/12 03:26 PM
Las Vegas
Las Vegas
Perhaps some of you replying here to the post should actually get out got the track and ask the manufacturers what they suggest for these tires in these types of applications. I do and have I also race one of these cars. The same class as the video is from. We all run 12" wheels as suggested we do from the manufacturer of the tire M/T for a 29.5x10.5 tire. On the outlaw 8.5 tire we use a 10"'wide rim as suggested by the tire techs from M/T.
The reasoning behind why we do has been pointed out here already. We get a bigger footprint and can run more air in the tires. But you can just read them catalogs and use those conservative recommendations. For those of us trying to truly maximize our programs we will continue to work with all the manufacturers to get the most we can from our cars.
Re: Check out this video...tire separating from the wheel [Re: Al_Alguire] #1272477
07/25/12 06:16 PM
07/25/12 06:16 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
It doesn't have a 509 cam, super stock springs, cop car or rallye wheels, nor a pinion snubber. . . . I wouldn't expect some of you to understand. Charlie has forgotten more race wins than many of us will ever have.
I'm Gumby dammit!
Re: Check out this video...tire separating from the wheel [Re: Gumbydammit] #1272478
07/25/12 08:04 PM
07/25/12 08:04 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Yep wider wheel=more footprint and stiffer sidewall. I'm sure his tires are glued on as well as screwed. I personally wouldn't run it like that though.
Re: Check out this video...tire separating from the wheel [Re: Al_Alguire] #1272479
07/25/12 08:24 PM
07/25/12 08:24 PM
Az
Crizila Offline
Crizila  Offline
Az
Ok, just looks unsafe to me. If you gotta run glue and a zillion rim screws ( 16 per side is the max they suggest ), I think bead locks would be in order. I would sacrifice a tenth or two and go with bead locks. I'm not that brave. I admire anyone who "pushes the envelope" - safely. JMO.
Fastest 300
Re: Check out this video...tire separating from the wheel [Re: Crizila] #1272480
07/25/12 08:46 PM
07/25/12 08:46 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
In Comp Eliminator we ran 24 screws per side of each rim. Besides keeping the tire from spinning on the rim the screws also stiffin the side wall. The screws change the way the sidewall works. We found the more screws the better the tire worked.
Page 2 of 4 1 2 3 4
