Lost all Oil Pressure today... 440 Magnum
#1270702
07/20/12 01:26 AM
07/20/12 01:26 AM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
So I've been commuting in my '70 Challenger, after getting off the backroads into town I was leaving a stop sign at low engine speed when it started ticking... Look at the gauge... Oh no!! 0 PSI! Shut it off and rolled to the side of the road... Checked the dipstick, oil looks black but its there, no metal that I could see. Fired it back up just in case the oil had moved away from the pickup.... still no pressure. Runs great though! Engine is a stock internally 1968 440 Magnum, headers, intake, Mallory distributor. I added the Mopar Performance high volume spring to the oil pump when it was out of the car. Tranny is a aluminum flywheel, Centerforce dual friction clutch, A833 OD. Guesses? I'm guessing (and hoping) its the oil pump and I didn't damage anything. Do oil pumps just "go bad"? Maybe the pressure spring broke? What else could it be?
Re: Lost all Oil Pressure today... 440 Magnum
[Re: RUNCHARGER]
#1270704
07/20/12 02:02 AM
07/20/12 02:02 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Or you popped a lifter out.... The pick up tube could have broken.. But yeah the relief valve or the drive shaft failed...
[Re: HemiRick]
#1270706
07/20/12 02:25 AM
07/20/12 02:25 AM
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
I vote one of these for sure, with broken oil pump driveshaft being my #1 most likely.
Okay, I'll check the driveshaft first!
How do I check the pressure relief valve in the oil pump?
I doubt it's a lifter because it still runs good, just makes a racket!
Thanks a ton guys!!
[Re: MoparforLife]
#1270708
07/20/12 02:43 AM
07/20/12 02:43 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Twisted the hex drive off the intermediate shaft.
Yeah. if the reg valve sticks open, there's still some pressure, increasing as you (ballsily) rev it.
Running a Mopar without the MP tapered / pinned shaft is like f****** the neighborhood ***** w/o a condom. Sooner or later...
Rick
[Re: rabid scott]
#1270711
07/20/12 08:05 AM
07/20/12 08:05 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I had a 400 in my Chrysler do the same thing.Pulled the pump and the drive was good.The pump took a crap.Was exactly like yours.Replaced the pump changed oil and filter and all was good.Rocky
Chrysler Firepower
