Lost all Oil Pressure today... 440 Magnum #1270702
07/20/12 01:26 AM
07/20/12 01:26 AM
Tracy CA
rabid scott Offline OP
"You're Where?"
"You're Where?"
Tracy CA
So I've been commuting in my '70 Challenger, after getting off the backroads into town I was leaving a stop sign at low engine speed when it started ticking... Look at the gauge... Oh no!! 0 PSI! Shut it off and rolled to the side of the road...
Checked the dipstick, oil looks black but its there, no metal that I could see. Fired it back up just in case the oil had moved away from the pickup.... still no pressure. Runs great though!
Engine is a stock internally 1968 440 Magnum, headers, intake, Mallory distributor. I added the Mopar Performance high volume spring to the oil pump when it was out of the car.
Tranny is a aluminum flywheel, Centerforce dual friction clutch, A833 OD.
Guesses?
I'm guessing (and hoping) its the oil pump and I didn't damage anything. Do oil pumps just "go bad"? Maybe the pressure spring broke?
What else could it be?
Re: Lost all Oil Pressure today... 440 Magnum [Re: rabid scott] #1270703
07/20/12 01:53 AM
07/20/12 01:53 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Valve stuck open in the oil pump or the oil pump driveshaft broke off.
Sheldon
Re: Lost all Oil Pressure today... 440 Magnum [Re: RUNCHARGER] #1270704
07/20/12 02:02 AM
07/20/12 02:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Or you popped a lifter out.... The pick up tube could have broken.. But yeah the relief valve or the drive shaft failed...
Re: Lost all Oil Pressure today... 440 Magnum [Re: 1_WILD_RT] #1270705
07/20/12 02:18 AM
07/20/12 02:18 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I vote one of these for sure, with broken oil pump driveshaft being my #1 most likely.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Lost all Oil Pressure today... 440 Magnum [Re: HemiRick] #1270706
07/20/12 02:25 AM
07/20/12 02:25 AM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
Okay, I'll check the driveshaft first!
How do I check the pressure relief valve in the oil pump?
I doubt it's a lifter because it still runs good, just makes a racket!
Thanks a ton guys!!
Re: Lost all Oil Pressure today... 440 Magnum [Re: rabid scott] #1270707
07/20/12 02:36 AM
07/20/12 02:36 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Twisted the hex drive off the intermediate shaft.
Re: Lost all Oil Pressure today... 440 Magnum [Re: MoparforLife] #1270708
07/20/12 02:43 AM
07/20/12 02:43 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Yeah. if the reg valve sticks open, there's still some pressure, increasing as you (ballsily) rev it.
Running a Mopar without the MP tapered / pinned shaft is like f****** the neighborhood ***** w/o a condom. Sooner or later...
Rick
Re: Lost all Oil Pressure today... 440 Magnum [Re: Rick_Ehrenberg] #1270709
07/20/12 03:27 AM
07/20/12 03:27 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Rick
Funny, the only one I ever had fail was a brand new MP part...... Took the pump off, found the broken tip, spun the pump with the original OE shaft to make sure the pump wasn't binding, replaced the new MP shaft with the OE shaft & never had another problem....
Re: Lost all Oil Pressure today... 440 Magnum [Re: 1_WILD_RT] #1270710
07/20/12 03:37 AM
07/20/12 03:37 AM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
Well, I hope it's just the shaft and the rest of the engine is still solid. Glad it didn't happen at 6500rpm!!
Thanks a ton guys!
Re: Lost all Oil Pressure today... 440 Magnum [Re: rabid scott] #1270711
07/20/12 08:05 AM
07/20/12 08:05 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had a 400 in my Chrysler do the same thing.Pulled the pump and the drive was good.The pump took a crap.Was exactly like yours.Replaced the pump changed oil and filter and all was good.Rocky
Chrysler Firepower
Re: Lost all Oil Pressure today... 440 Magnum [Re: rabid scott] #1270712
07/20/12 08:40 AM
07/20/12 08:40 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Mine did same..cam lobe wore down and pushrod came out causing "0" oil pressure.....
