Or you popped a lifter out.... The pick up tube could have broken.. But yeah the relief valve or the drive shaft failed...
I vote one of these for sure, with broken oil pump driveshaft being my #1 most likely.
Okay, I'll check the driveshaft first!
How do I check the pressure relief valve in the oil pump?
I doubt it's a lifter because it still runs good, just makes a racket!
Thanks a ton guys!!
