Runner up Finish!!! Video added #1256401
06/24/12 12:20 PM
06/24/12 12:20 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Kudos to w2dak394 in the W2 headed small block Ltl Red Express Dakota. Runner up finish at Jackson Dragway last night( er....this morning).
Andy 3965 was there as the crewchief... Not a bad combo.
Congrats to both my younger brothers. Keep digging, a win is right around the corner!!!
I hope this works. The link should take you to my youtube site.
http://www.youtube.com/watch?v=IZbfZB0bFdg&feature=plcp
If it doesnt work do A search for iraceamopar
Allen
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: Runner up Finish!!! [Re: mopar97] #1256402
06/24/12 01:20 PM
06/24/12 01:20 PM
ky
68roadrunner Offline
ky
good job to the guys on the runner up. keep at it. hope jackson treats you well. have not been there in the last year.
Re: Runner up Finish!!! [Re: mopar97] #1256403
06/24/12 02:01 PM
06/24/12 02:01 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
Good job guys keep trying the win is right around the corner.
Re: Runner up Finish!!! [Re: Red440] #1256404
06/24/12 02:02 PM
06/24/12 02:02 PM
tboomer Offline
tboomer  Offline
Congrats!!
Re: Runner up Finish!!! [Re: tboomer] #1256405
06/25/12 01:40 PM
06/25/12 01:40 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Video is up for those intrested.
Thanx
Allen
Re: Runner up Finish!!! [Re: mopar97] #1256406
06/26/12 10:27 PM
06/26/12 10:27 PM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
If by crew chief you mean checking tire pressure and writting the dial in time on the window then I guess i'm a crew chief
We could have finished first because we were closer to our dial in, but someone got caught sleeping
The truck is running good for what it is, but soon to run better, I just sent RyanJ a money order for a set of chapman cnc w-9's that he has touched up by hand. They will be completely set up and ready to run with T&D 1.7 ratio rockers.
I havent figured out how many cubes it will be yet, but I alrady have the R-block, cam, intake, and now the heads.
will probably be somewhere in the 422" or larger range. Ryan said we should be able to get close to 800hp out of it
It will be a big step up from the 394 W2headed 340 stroker we are running now.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: Runner up Finish!!! [Re: andy3965] #1256407
06/27/12 12:53 AM
06/27/12 12:53 AM
ky
ky
sounds like a crew chief to me, sounds like your going to step it up quite a bit, good luck
Re: Runner up Finish!!! [Re: 68roadrunner] #1256408
06/27/12 09:07 AM
06/27/12 09:07 AM
ms
W
w2dak394 Offline
w2dak394  Offline
W
ms
Well you slept all the way to the track, so i had to get a nap also. Thaks for coming to track to hang out with your brothers.(Allen)
