If by crew chief you mean checking tire pressure and writting the dial in time on the window then I guess i'm a crew chief
We could have finished first because we were closer to our dial in, but someone got caught sleeping
The truck is running good for what it is, but soon to run better, I just sent RyanJ a money order for a set of chapman cnc w-9's that he has touched up by hand. They will be completely set up and ready to run with T&D 1.7 ratio rockers.
I havent figured out how many cubes it will be yet, but I alrady have the R-block, cam, intake, and now the heads.
will probably be somewhere in the 422" or larger range. Ryan said we should be able to get close to 800hp out of it
It will be a big step up from the 394 W2headed 340 stroker we are running now.
