If by crew chief you mean checking tire pressure and writting the dial in time on the window then I guess i'm a crew chief
We could have finished first because we were closer to our dial in, but someone got caught sleeping
![](/ubbthreads/images/graemlins/whistling.gif)
The truck is running good for what it is, but soon to run better, I just sent RyanJ a money order for a set of chapman cnc w-9's that he has touched up by hand. They will be completely set up and ready to run with T&D 1.7 ratio rockers.
I havent figured out how many cubes it will be yet, but I alrady have the R-block, cam, intake, and now the heads.
will probably be somewhere in the 422" or larger range. Ryan said we should be able to get close to 800hp out of it
![](/ubbthreads/images/graemlins/punkrocka.gif)
It will be a big step up from the 394 W2headed 340 stroker we are running now.
