Re: found this under the car (afco shock users)
[Re: Deepockets]
#1248876
06/11/12 02:05 AM
06/11/12 02:05 AM
Posts: 2,864 IN
Irun5snd8th
IN
This may be a sign that you need to tighten the compression on the shock to keep it from coming down to the point that is crushes that bumper. Thinking you may be coming down hard enough to hit the bumper (what you have pictured) and cause it to blow out like this. Those are over an inch thick and it is not uncommon for people to cut those down to a shorter height.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#1248877
06/11/12 12:47 PM
06/11/12 12:47 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Bumper?.... Looks like the lower shock bushing to me.
[Re: Irun5snd8th]
#1248878
06/11/12 01:40 PM
06/11/12 01:40 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Same here . Quote:
So thats what I did
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Irun5snd8th]
#1248880
06/11/12 07:09 PM
06/11/12 07:09 PM
Posts: 43 IN
EricatAFCO
IN
Deep, That part is a shock bumper. You probably have already looked at the other shock for damage to that bumper as well ti verify. Part of our quality control process is to test samples up to and including the yield point. In this case, bumpers will split down the side when crushed to their limit. Others have suggested that you tighten up compression, which is the correct adjustment. (It's ok to even go full tight if needed to land smoothly) Even though the car didn't land hard, the bumper gave of itself to prevent that. Bumpers are not too expensive. They cost $7.07 each. Feel free to contact me if you don't have an AFCO dealer to order them from. I can be reached at eesaffell@afcoracing.com. Eric
[Re: Irun5snd8th]
#1248881
06/11/12 07:12 PM
06/11/12 07:12 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Is it an actual 'bumper', or more of just a 'travel indicator'. On mine, I figured it was just an added feature(instead of the old tried/true wire tie around the shaft) to aid in adjusting the shocks' travel. The material it is made of, I would not think would be heavy duty enough for a bumper.. Also, the damage to the rubber piece, probably happened in the trailer while towing, not on the track...unless you tie the car down by the frame and eliminate suspension travel while transporting.. Sorry,,,after re-reading the post, I see you are talking FRONT shocks
If you like drag racing, support your local track.
[Re: CHAPPER]
#1248882
06/11/12 07:19 PM
06/11/12 07:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its a bumper but its not designed to be bottomed out
[Re: EricatAFCO]
#1248884
06/11/12 08:30 PM
06/11/12 08:30 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Deep,
Others have suggested that you tighten up compression, which is the correct adjustment. (It's ok to even go full tight if needed to land smoothly) Even though the car didn't land hard, the bumper gave of itself to prevent that. Bumpers are not too expensive. They cost $7.07 each. Feel free to contact me if you don't have an AFCO dealer to order them from. I can be reached at [Email]eesaffell@afcoracing.com.[/Email]
Eric
Very cool of you to be here and make that offer
[Re: Deepockets]
#1248885
06/11/12 09:19 PM
06/11/12 09:19 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
must be cumming down hard for that to happing
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
