found this under the car (afco shock users) #1248875
06/10/12 11:58 PM
06/10/12 11:58 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
not bashing in any way. went to take the car out of the trailer and found this laying on the ground. it's the cushion off the left front shock. my car pulls the wheels about 6" and comes down without slamming. it seamed to pull apart preaty easy. anyone else here lose theres?
Re: found this under the car (afco shock users) [Re: Deepockets] #1248876
06/11/12 02:05 AM
06/11/12 02:05 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
This may be a sign that you need to tighten the compression on the shock to keep it from coming down to the point that is crushes that bumper. Thinking you may be coming down hard enough to hit the bumper (what you have pictured) and cause it to blow out like this. Those are over an inch thick and it is not uncommon for people to cut those down to a shorter height.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: found this under the car (afco shock users) [Re: Irun5snd8th] #1248877
06/11/12 12:47 PM
06/11/12 12:47 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Bumper?.... Looks like the lower shock bushing to me.
Re: found this under the car (afco shock users) [Re: Irun5snd8th] #1248878
06/11/12 01:40 PM
06/11/12 01:40 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Same here .
So thats what I did
Re: found this under the car (afco shock users) [Re: StealthWedge67] #1248879
06/11/12 06:48 PM
06/11/12 06:48 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Thats definitely one of the bumpers and its made of a lightweight foam material.
Re: found this under the car (afco shock users) [Re: Irun5snd8th] #1248880
06/11/12 07:09 PM
06/11/12 07:09 PM
IN
E
EricatAFCO Offline
EricatAFCO  Offline
E
IN
Deep,
That part is a shock bumper. You probably have already looked at the other shock for damage to that bumper as well ti verify. Part of our quality control process is to test samples up to and including the yield point. In this case, bumpers will split down the side when crushed to their limit.
Others have suggested that you tighten up compression, which is the correct adjustment. (It's ok to even go full tight if needed to land smoothly) Even though the car didn't land hard, the bumper gave of itself to prevent that. Bumpers are not too expensive. They cost $7.07 each. Feel free to contact me if you don't have an AFCO dealer to order them from. I can be reached at eesaffell@afcoracing.com.
Eric
Re: found this under the car (afco shock users) [Re: Irun5snd8th] #1248881
06/11/12 07:12 PM
06/11/12 07:12 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Is it an actual 'bumper', or more of just a 'travel indicator'. On mine, I figured it was just an added feature(instead of the old tried/true wire tie around the shaft) to aid in adjusting the shocks' travel. The material it is made of, I would not think would be heavy duty enough for a bumper.. Also, the damage to the rubber piece, probably happened in the trailer while towing, not on the track...unless you tie the car down by the frame and eliminate suspension travel while transporting..
Sorry,,,after re-reading the post, I see you are talking FRONT shocks
If you like drag racing, support your local track.
Re: found this under the car (afco shock users) [Re: CHAPPER] #1248882
06/11/12 07:19 PM
06/11/12 07:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a bumper but its not designed to be bottomed out
Re: found this under the car (afco shock users) [Re: MR_P_BODY] #1248883
06/11/12 07:40 PM
06/11/12 07:40 PM
glendora, ca.
glendora, ca.
thanks, i ran them stiffer than what they sugguested from the git go, i guess i'll go stiffer. thanks for all the advise.
Re: found this under the car (afco shock users) [Re: EricatAFCO] #1248884
06/11/12 08:30 PM
06/11/12 08:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Deep,
Others have suggested that you tighten up compression, which is the correct adjustment. (It's ok to even go full tight if needed to land smoothly) Even though the car didn't land hard, the bumper gave of itself to prevent that. Bumpers are not too expensive. They cost $7.07 each. Feel free to contact me if you don't have an AFCO dealer to order them from. I can be reached at [Email]eesaffell@afcoracing.com.[/Email]
Eric
Very cool of you to be here and make that offer
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: found this under the car (afco shock users) [Re: Deepockets] #1248885
06/11/12 09:19 PM
06/11/12 09:19 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
must be cumming down hard for that to happing
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
