Re: cooling problems
[Re: 471b1dart]
#1237375
05/21/12 09:23 PM
05/21/12 09:23 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's rare for a pump to fail where it won't move water. Maybe the rotor fell off.
I guess you opened the radiator then warmed up the engine to see if water was moving?
Is the upper radiator hose getting hot?
Grab a temp gun and start looking for cold spots in the cooling system. That will show you where the water isn't moving.
[Re: 471b1dart]
#1237376
05/21/12 09:57 PM
05/21/12 09:57 PM
RapidRobert
partly plugged rad. I'm assuming there's a proper fan/shroud in place
[Re: 471b1dart]
#1237381
05/22/12 09:37 PM
05/22/12 09:37 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
pretty sure I found the problem , the lower rad hose is collapsing as soon as you take the engine any amount above Idle, it sat and idled 30+min at 190* but climbed steady and fast when reving the engine. thanks for all the sugestions on where to look
I had the same problem... I tried finding a lower rad hose that had the wire spring in it, and had no luck. I bought a generic upper rad hose in the same diameter that had the spring inside it, .. pulled the spring out, and put it in my lower hose.. no more collapsing hose
