RapidRobert ... you helped me out with my problem on my 340 last year.
It ended up being a worn pump shaft where the impeller would freewheel intermittently... I never thought it was possible, and it was the craziest thing to sort out, but in the end it was the easiest fix...
https://board.moparts.org/ubbthreads/show...rue#Post6857083
