cooling problems #1237374
05/21/12 08:49 PM
05/21/12 08:49 PM
Fredericton NB Canada
471b1dart Offline OP
took my road runner for a short drive and it got up to 250* , came home changed thermostat same thing again , took therostat out , same problem , Its a 70 with a 383 pretty much stock, 26" rad that looks new , but noticed not much coolant circulating could the water pump go bad with out leaking??
Re: cooling problems [Re: 471b1dart] #1237375
05/21/12 09:23 PM
05/21/12 09:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's rare for a pump to fail where it won't move water. Maybe the rotor fell off.
I guess you opened the radiator then warmed up the engine to see if water was moving?
Is the upper radiator hose getting hot?
Grab a temp gun and start looking for cold spots in the cooling system. That will show you where the water isn't moving.
- Stu Harmon
Re: cooling problems [Re: 471b1dart] #1237376
05/21/12 09:57 PM
05/21/12 09:57 PM
partly plugged rad. I'm assuming there's a proper fan/shroud in place
Re: cooling problems [Re: RapidRobert] #1237377
05/21/12 10:14 PM
05/21/12 10:14 PM
New York
EF8aar Offline
EF8aar  Offline
New York
RapidRobert ... you helped me out with my problem on my 340 last year.
It ended up being a worn pump shaft where the impeller would freewheel intermittently... I never thought it was possible, and it was the craziest thing to sort out, but in the end it was the easiest fix...
https://board.moparts.org/ubbthreads/show...rue#Post6857083
Re: cooling problems [Re: feets] #1237378
05/21/12 10:18 PM
05/21/12 10:18 PM
both hoses getting hot , has a recored rad a 7 blade none clutch fan , also has the shroud
Re: cooling problems [Re: 471b1dart] #1237379
05/21/12 11:28 PM
05/21/12 11:28 PM
IN
ahy Offline
ahy  Offline
IN
Pretty easy to pull the WP and check it out. That's what I'd do next.
Re: cooling problems [Re: RapidRobert] #1237380
05/22/12 09:35 PM
05/22/12 09:35 PM
pretty sure I found the problem , the lower rad hose is collapsing as soon as you take the engine any amount above Idle, it sat and idled 30+min at 190* but climbed steady and fast when reving the engine. thanks for all the sugestions on where to look
Re: cooling problems [Re: 471b1dart] #1237381
05/22/12 09:37 PM
05/22/12 09:37 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
I had the same problem... I tried finding a lower rad hose that had the wire spring in it, and had no luck. I bought a generic upper rad hose in the same diameter that had the spring inside it, .. pulled the spring out, and put it in my lower hose.. no more collapsing hose
Re: cooling problems [Re: cal_gecko] #1237382
05/22/12 10:22 PM
05/22/12 10:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I fixed that problem with a wire coat hanger.
- Stu Harmon
Re: cooling problems [Re: feets] #1237383
05/23/12 06:40 AM
05/23/12 06:40 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
^^^ What he said....coat hanger and a PVC pipe...coil it around and slip it in
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
