Re: Sealing pinhole in aluminum heads
[Re: super451b]
#1208317
04/02/12 08:21 PM
04/02/12 08:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Seal All is an excellent product if used right.Its not cheap, but it will work perfectly. Many shops that do extensive porting use it on everything they touch. NASCAR used it as well.
RIP Monte Smith
[Re: MCHBOB]
#1208319
04/03/12 01:20 AM
04/03/12 01:20 AM
Posts: 2,091 Delray beach, Florida
Performance Only
i was thinking the same thing. i wouldn't put it back together just to put a sealer in it. weld it now and forget about it.
machine shop owner and engine builder
[Re: super451b]
#1208321
04/03/12 10:20 AM
04/03/12 10:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Is that the kind that you pour in the radiator? I have the heads off right now.
Since you said the head is off.... have it welded
[Re: super451b]
#1208323
04/03/12 12:50 PM
04/03/12 12:50 PM
CompWedgeEngines
Syracuse,NY
It seems that a couple of people are confused with the Seal All process. Its not something you pour into a engine that is already together. This is a sealer thats done with the head already off.Two totally different process'.Most often used to protect proting jobs and so forth, and it DOES work, IF done right.This isnt a can in the radiator fix.
I would tend to agree, if its off already, then weld it.
I answered the question that was asked. I was assuming there may be a reason the OP didnt want to, or possibly couldnt weld it. Dont know for sure.
RIP Monte Smith
[Re: CompWedgeEngines]
#1208324
04/03/12 01:14 PM
04/03/12 01:14 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Devcon or Hysol EA934, both 2 part epoxies with aluminum powder in the base. Both high-temp, aviation grade products. Once cured, they are harder than the aluminum.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: B G Racing]
#1208326
04/03/12 02:47 PM
04/03/12 02:47 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I saved this post from speed talk after reading it just in case I had one that I couldn't weld up. http://speedtalk.com/forum/viewtopic.php?f=15&t=26040
[Re: pittsburghracer]
#1208327
04/03/12 07:25 PM
04/03/12 07:25 PM
Posts: 854 Bloomingdale , OH
super451b
Bloomingdale , OH
Thats why I asked about alternatives to welding. The hole is in a very tough spot to get to , at least with the equipment that I have. It's right where the port floor starts to transition into the short side radius. I have everything here, that I would need , to try the seal-all. Cost is also a factor. The plant that I worked at closed last fall and I havent been able to find anything that comes close to what I was making before, so my race car budget is substantially less than it used to be.
[Re: super451b]
#1208328
04/03/12 08:48 PM
04/03/12 08:48 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Wade,bring it buy the shop and we will take a look at it and try to fix it for you,no charge
