Sealing pinhole in aluminum heads #1208309
04/02/12 03:32 PM
04/02/12 03:32 PM
Bloomingdale , OH
super451b Offline OP
Bloomingdale , OH
Hi guys, I've got a pinhole in the intake port on one of my EZ heads, that's leaking water. Is there a good sealer that will fix this ? Or will it have to be welded?
Thanks, Wade
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208310
04/02/12 03:40 PM
04/02/12 03:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a ceramic block sealer thats real good...
and lasts... you can get it at the auto parts store
Re: Sealing pinhole in aluminum heads [Re: MR_P_BODY] #1208311
04/02/12 03:54 PM
04/02/12 03:54 PM
Bloomingdale , OH
Bloomingdale , OH
Is that the kind that you pour in the radiator? I have the heads off right now.
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208312
04/02/12 04:43 PM
04/02/12 04:43 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Yes, you pour it in the radiator and there are specific instructions for getting heat in the motor for making it work. Off the car I think welding or metal stitching are your only options for an area under pressure.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208313
04/02/12 06:53 PM
04/02/12 06:53 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it's just one pinhole,rub some LabMetal or similar in it and lightly peen it over.Then when engine is run(heat cycled) pour some Dyke Sealer or similar in the cooling system.Use as instructed.
Re: Sealing pinhole in aluminum heads [Re: B G Racing] #1208314
04/02/12 07:14 PM
04/02/12 07:14 PM
Bloomingdale , OH
Bloomingdale , OH
Thanks guys, while I was looking around on the web , I found this : http://www.angelfire.com/biz/sealall/
Has anyone here ever tried it ?
Re: Sealing pinhole in aluminum heads [Re: Dads426] #1208315
04/02/12 07:15 PM
04/02/12 07:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
head is off. repair it right. get it welded.
Re: Sealing pinhole in aluminum heads [Re: rickraw] #1208316
04/02/12 08:10 PM
04/02/12 08:10 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
the last thing you want to do is pull the head off if it leaks again
1.39 9.85 - 137 mph
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208317
04/02/12 08:21 PM
04/02/12 08:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Seal All is an excellent product if used right.Its not cheap, but it will work perfectly. Many shops that do extensive porting use it on everything they touch. NASCAR used it as well.
RIP Monte Smith
Re: Sealing pinhole in aluminum heads [Re: CompWedgeEngines] #1208318
04/03/12 12:53 AM
04/03/12 12:53 AM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
If you go with a sealer and it doesnt work.Your gonna give the guy that will try welding it up a nightmare Hence why i said TRY.Hes gonna fight welding it up with that crap contaminating the weld.It'll go something like weld grind weld grind weld grind pressure test weld grind pressure test weld grind.Add a sealer you can turn a 5 min weld repair into a whole days job
If the head is off why would you not weld it????
Re: Sealing pinhole in aluminum heads [Re: MCHBOB] #1208319
04/03/12 01:20 AM
04/03/12 01:20 AM
Delray beach, Florida
P
Performance Only Offline
P
i was thinking the same thing. i wouldn't put it back together just to put a sealer in it. weld it now and forget about it.
machine shop owner and engine builder
Re: Sealing pinhole in aluminum heads [Re: Performance Only] #1208320
04/03/12 02:36 AM
04/03/12 02:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
By all means if you have it apart I would just weld it now. Ron
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208321
04/03/12 10:20 AM
04/03/12 10:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Since you said the head is off.... have it welded
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208322
04/03/12 12:30 PM
04/03/12 12:30 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208323
04/03/12 12:50 PM
04/03/12 12:50 PM
Syracuse,NY
Syracuse,NY
It seems that a couple of people are confused with the Seal All process. Its not something you pour into a engine that is already together. This is a sealer thats done with the head already off.Two totally different process'.Most often used to protect proting jobs and so forth, and it DOES work, IF done right.This isnt a can in the radiator fix.
I would tend to agree, if its off already, then weld it.
I answered the question that was asked. I was assuming there may be a reason the OP didnt want to, or possibly couldnt weld it. Dont know for sure.
RIP Monte Smith
Re: Sealing pinhole in aluminum heads [Re: CompWedgeEngines] #1208324
04/03/12 01:14 PM
04/03/12 01:14 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Devcon or Hysol EA934, both 2 part epoxies with aluminum powder in the base. Both high-temp, aviation grade products. Once cured, they are harder than the aluminum.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Sealing pinhole in aluminum heads [Re: Slingshot383] #1208325
04/03/12 01:25 PM
04/03/12 01:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it has already been run and sealer and other contaminates are present then you maybe in for a PIA weld job.If it's a thin area you may create a bigger project.
Re: Sealing pinhole in aluminum heads [Re: B G Racing] #1208326
04/03/12 02:47 PM
04/03/12 02:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I saved this post from speed talk after reading it just in case I had one that I couldn't weld up. http://speedtalk.com/forum/viewtopic.php?f=15&t=26040
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Sealing pinhole in aluminum heads [Re: pittsburghracer] #1208327
04/03/12 07:25 PM
04/03/12 07:25 PM
Bloomingdale , OH
Bloomingdale , OH
Thats why I asked about alternatives to welding. The hole is in a very tough spot to get to , at least with the equipment that I have. It's right where the port floor starts to transition into the short side radius. I have everything here, that I would need , to try the seal-all.
Cost is also a factor. The plant that I worked at closed last fall and I havent been able to find anything that comes close to what I was making before, so my race car budget is substantially less than it used to be.
Re: Sealing pinhole in aluminum heads [Re: super451b] #1208328
04/03/12 08:48 PM
04/03/12 08:48 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Wade,bring it buy the shop and we will take a look at it and try to fix it for you,no charge
