Re: PISTON RING SUGGESTIONS...440???
[Re: Labratt]
#1173835
02/07/12 01:03 PM
02/07/12 01:03 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
No need to even worry about getting fancy with a ring pack for that Randy. Go with moly top, ductile, standard or mid tension oil, and dont waste anymore time on it. That application simply doesnt require anything else.
I really like the Mahle rings. Nice flat finish, fit and size well, and they have a smooth fit.
They old tried and true Sealed Power almost always work well, just at a much higher cost.Been using the Total Seal CR series for many many years as well.
I'm not sold on the NEED for gapless, other than a few specific ( usually some alcohol) type engines.
RIP Monte Smith
[Re: abodiesonly1]
#1173837
02/07/12 01:11 PM
02/07/12 01:11 PM
Posts: 5,875 communist bloc of new jersey
jamesc
there's your answer
[Re: CompWedgeEngines]
#1173839
02/07/12 04:31 PM
02/07/12 04:31 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
[Re: Labratt]
#1173842
02/07/12 06:54 PM
02/07/12 06:54 PM
Posts: 3,395 Pa
Hot 340
Pa
Steff,I plan on honing the cylinders myself. I still have to purchase a hone to do it. Raff only has small block hones...or I'd borrow one of his!
Id do it with a plate and sunnen machine Randy. Better end result for cheap.
[Re: Hot 340]
#1173843
02/07/12 09:29 PM
02/07/12 09:29 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Sealed Power rings,,,moly top, ductile second, standard tension oil rings,,file fit,,not gapless...plate honed...your 'good to go'.
If you like drag racing, support your local track.
[Re: Labratt]
#1173850
02/08/12 01:06 PM
02/08/12 01:06 PM
CompWedgeEngines
Syracuse,NY
You do want to use a plate.
The BEST rear seal holder is a nice piece. I use both theirs and Indys without any issues.
Use the Superformance rear seal and side seals.
RIP Monte Smith
[Re: Cab_Burge]
#1173852
02/09/12 01:25 AM
02/09/12 01:25 AM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Damon,I believe when the honing plates are torqued to spec(same as head torque specs) that it simulates the actual "distortion" of the shape of the cylinder...making the process more accurate...and ring sealing more effective!
Absolutely needed if you want to make the most power you can right away
Thanks. Good to know. I was thinking it was necessary for boring but not honing.
Damon
