PISTON RING SUGGESTIONS...440??? #1173834
02/07/12 12:59 PM
02/07/12 12:59 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I'm in the process of freshening-up the .040 over 440 in my GTX. When it was rebuilt 6 yrs. ago,Total Seal "Gapless" rings were used. I believe some of the blame for oil getting past the rings...and into the combustion chambers,could be attributed to the rings..along with intake port gaskets. What are your recommendations for a street/strip,11:1 comp. 440? Thanks in advance for your help! Randy B.
Re: PISTON RING SUGGESTIONS...440??? [Re: Labratt] #1173835
02/07/12 01:03 PM
02/07/12 01:03 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
No need to even worry about getting fancy with a ring pack for that Randy. Go with moly top, ductile, standard or mid tension oil, and dont waste anymore time on it. That application simply doesnt require anything else.
I really like the Mahle rings. Nice flat finish, fit and size well, and they have a smooth fit.
They old tried and true Sealed Power almost always work well, just at a much higher cost.Been using the Total Seal CR series for many many years as well.
I'm not sold on the NEED for gapless, other than a few specific ( usually some alcohol) type engines.
RIP Monte Smith
Re: PISTON RING SUGGESTIONS...440??? [Re: CompWedgeEngines] #1173836
02/07/12 01:09 PM
02/07/12 01:09 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
R 9278 045 Sealed Power File Fits
Re: PISTON RING SUGGESTIONS...440??? [Re: abodiesonly1] #1173837
02/07/12 01:11 PM
02/07/12 01:11 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there's your answer
Re: PISTON RING SUGGESTIONS...440??? [Re: jamesc] #1173838
02/07/12 02:45 PM
02/07/12 02:45 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,guys! I just want to go with a proven ring combo! Definately don't want the oil control problem after I put the motor back together! I will also be buying a better rear main seal holder! My stock one has oil all over the back of the block! Best Machine?...Indy? Sounds like they both work well!
Re: PISTON RING SUGGESTIONS...440??? [Re: CompWedgeEngines] #1173839
02/07/12 04:31 PM
02/07/12 04:31 PM
Re: PISTON RING SUGGESTIONS...440??? [Re: Cab_Burge] #1173840
02/07/12 05:41 PM
02/07/12 05:41 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
You getting the block honed for the new rings?
Re: PISTON RING SUGGESTIONS...440??? [Re: STEFF] #1173841
02/07/12 06:00 PM
02/07/12 06:00 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Steff,I plan on honing the cylinders myself. I still have to purchase a hone to do it. Raff only has small block hones...or I'd borrow one of his!
Re: PISTON RING SUGGESTIONS...440??? [Re: Labratt] #1173842
02/07/12 06:54 PM
02/07/12 06:54 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Id do it with a plate and sunnen machine Randy. Better end result for cheap.
Re: PISTON RING SUGGESTIONS...440??? [Re: Hot 340] #1173843
02/07/12 09:29 PM
02/07/12 09:29 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Sealed Power rings,,,moly top, ductile second, standard tension oil rings,,file fit,,not gapless...plate honed...your 'good to go'.
If you like drag racing, support your local track.
Re: PISTON RING SUGGESTIONS...440??? [Re: CHAPPER] #1173844
02/07/12 09:56 PM
02/07/12 09:56 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
it would be good money spent to have it honed by machine like mentioned. thats my preferance.
Re: PISTON RING SUGGESTIONS...440??? [Re: Deepockets] #1173845
02/07/12 10:19 PM
02/07/12 10:19 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for your advice,guys...to the machine shop the block will go! I hear ya on using honing plates..that IS the way to go!
Re: PISTON RING SUGGESTIONS...440??? [Re: Labratt] #1173846
02/08/12 12:51 AM
02/08/12 12:51 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
I'm no engine builder but I thought that honing didn't need the plates? Any Pro's have a some input?
Damon
Re: PISTON RING SUGGESTIONS...440??? [Re: mopardamo] #1173847
02/08/12 01:38 AM
02/08/12 01:38 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Damon,I believe when the honing plates are torqued to spec(same as head torque specs) that it simulates the actual "distortion" of the shape of the cylinder...making the process more accurate...and ring sealing more effective!
Re: PISTON RING SUGGESTIONS...440??? [Re: Labratt] #1173848
02/08/12 02:36 AM
02/08/12 02:36 AM
Absolutely needed if you want to make the most power you can right away
Re: PISTON RING SUGGESTIONS...440??? [Re: Cab_Burge] #1173849
02/08/12 01:03 PM
02/08/12 01:03 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Cab! Any suggestions on an after market rear main seal holder? I DO NOT trust using the stock one again! NO OIL LEAKS ALLOWED!!!
Re: PISTON RING SUGGESTIONS...440??? [Re: Labratt] #1173850
02/08/12 01:06 PM
02/08/12 01:06 PM
Syracuse,NY
Syracuse,NY
You do want to use a plate.
The BEST rear seal holder is a nice piece. I use both theirs and Indys without any issues.
Use the Superformance rear seal and side seals.
RIP Monte Smith
Re: PISTON RING SUGGESTIONS...440??? [Re: CompWedgeEngines] #1173851
02/08/12 01:21 PM
02/08/12 01:21 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,Todd! I'll be in touch with Greg today,or tomorrow...I'll ask him about the seals then. Take care! Randy
Re: PISTON RING SUGGESTIONS...440??? [Re: Cab_Burge] #1173852
02/09/12 01:25 AM
02/09/12 01:25 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Thanks. Good to know. I was thinking it was necessary for boring but not honing.
Damon
