Re: kickdown bracket/linkage question
[Re: bigdaddywiz]
#1169856
02/01/12 11:18 AM
02/01/12 11:18 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
First, I would start with contacting Lokar or Holley to see if they have adapters for your carb to mate with the cable. This is because you have already bought the cable. Next I just used a longer piece to reach the linkage on the Holley. I actually used one from a /6 it's a little curved on the front end but works fine with my set-up. Can't swear it will work on your set up but I have read of several guys that just welded two together to get the length they needed. This also leads me to believe that all you need is a longer piece. Hope this helps.
I have mechanical Aptitude. I can screw up anything.
[Re: scratchnfotraction]
#1169858
02/01/12 12:44 PM
02/01/12 12:44 PM
Posts: 124 Pittsburgh, PA
bigdaddywiz
Pittsburgh, PA
i will post pics as soon as i get home from work... i believe this is considered a 3 piece bracket, but the rod is one solid piece. this is a 73 road runner with a 318 and 904. i installed a 340 manifold with a 4bbl holley that came with it (old style carb). like i said, i'll get pics asap thank you! Quote:
I have some throttle brackets
what kickdown do you need?
3 piece or a one piece?
post a pic of the intake carb a little further back.
what car is this again?
[Re: bigdaddywiz]
#1169859
02/01/12 06:54 PM
02/01/12 06:54 PM
Posts: 15,487 Florida
scratchnfotraction
I forgot where we left off talking last time,sorry. the intake bracket you have now that wont fit,what 2 bolts does it want to go on when it mounts on the intake? IIRC you will need a bracket that jumps over the intake runners and goes on the bolts next to the runners each side. I will dig up the brackets and pop some pics for you as well. IIRC the 1 piece 73-74 TP linkage has the adjustment right at the intake bracket pivot point. you need the bracket that fits the intake and the 1 piece rod set up you have,maybe it will then work. make another post asking for 73-74 SB 4-v linkage set ups and see what a stock set up looks like... see if anyone has converted to a 3-piece on that body style
#1169860
02/02/12 10:49 AM
02/02/12 10:49 AM
bigdaddywiz
Pittsburgh, PA
thanks buddy, i really appreciate the help!
attached is a picture of my carb. you are correct that i need one that clears the intake and it bolts to the second to last bolt, and the next one over which would be 3rd to last.
its holley 6210 model 4165, 650cfm spreadbore manual double pumper
so i should post in the Q and A board for that setup, you meant just for pics right?
[Re: bigdaddywiz]
#1169861
02/02/12 12:24 PM
02/02/12 12:24 PM
scratchnfotraction
yes, Q&A board asking for pics of a stock 73-74 318/340/360 4-v set up and what ever stock carb came on it.
seems another carb would be the ez-est thing to do also, IIRC thats a mopar throttle lever thats on it but then again I am not sure.
my 6210/4165 650 spredbore DP has a different lever and will use a holley/chrysler throttle adaptor.
is the idea of another carb out for you?
I know you have $ sunk in it now but maybe an option to ez the pain.
I may have one you can have if it will help.
#1169862
02/02/12 01:51 PM
02/02/12 01:51 PM
bigdaddywiz
Pittsburgh, PA
Another carb isn't out of the question...I just don't want to spend too much more on this.
What kind of carb is it that you can part with and does it need anything?
Thanks again!
[Re: Paul_Fancsali]
#1169864
02/02/12 06:00 PM
02/02/12 06:00 PM
scratchnfotraction
Come out to the south hills and I will show you how to make it work. You need the holley extension and I have the correct bracket and a kickdown rod that is off a Dodge trk little welding and your set
unless there is another holley/chrysler/mopar adaptor that bolts to that style holley throttle lever am am not seeing how you will use it on that carb.
I guess one could swap the throttle lever and tac weld another on...I do that to the q-jets and mopat throttle levers for truck linkage.
[Re: Paul_Fancsali]
#1169866
02/02/12 09:05 PM
02/02/12 09:05 PM
bigdaddywiz
Pittsburgh, PA
If that is the case gettinga proper bracket should align to the carb and allow theuseof lokar cable
Right now I am using an aftermarket high rise adjustable bracket which properly aligns the throttle cable, but only has fittings for the lokar cable, but as we know, doesn't work with my carb.
I have no welding skills so am I just going to have to get another carb and be done with this?
[Re: bigdaddywiz]
#1169867
02/03/12 12:04 PM
02/03/12 12:04 PM
scratchnfotraction
do you have your old post saved from last summer? IIRC John Kunkle said what type carb throttle lever it has,early mopar maybe. sent you a PM post the # from your carb again,lets see what it for. I know mine is the same thing but list for chebby with a chebby throttle arm,the holley adaptor will bolt to it unlike yours. which to me with the mopar throttle stud looks stock mopar and should work with some sort of stock linkage set up.
#1169868
02/04/12 12:54 PM
02/04/12 12:54 PM
scratchnfotraction
ok,dug up some brackets out of the shed.
i have the tall 4-v bracket that should bolt to the intake,and the flat bar hook to the stud on the carb you have now.
I will post a pic of 2 flat rods,i am holding them together,you drill 2 holes and bolt them together to make the flat bar longer if needed(which i think you will need to do)
you 1 piece rod should go right on to this bellcrank,may have to figure inside or out on the bellcrank. (i took pic of the mock up rod on either side if you look close at the pics to see how it goes on the bellcrank)
my LD4B is slightly taller at the runners inbetween the bolts,but this bracke is the same on my stock 4-v intake and fits both...most times the carb flat bar needs to be longer but fits)i will get this bracket and 2 flat bars on the way to you Monday,then we can go from there when you get it bolted to the intake and see were we are at hooking up the flat rods to the carb stud.
#1169870
02/04/12 12:57 PM
02/04/12 12:57 PM
scratchnfotraction
and another shot look at the 1st pic and this pic... see how i turned the bellcrank around and changed the way the flat bar and linkage rod went on. try both ways to see which way works best for you. on my SB the LD4B/eddy carb went 1 way...on the stock intake with stock q-jet it flips around the other way. the eddy used the mopar adaptor and needed 2 flat bar bolted together,the stock intake/q-jet flips the other way and fits with 1 flat bar...as this is stock for a truck with a q-jet in 85. the flat bar can go on either side of the rod,which ever fits best is the way i do it.
#1169872
02/04/12 01:07 PM
02/04/12 01:07 PM
scratchnfotraction
now what i need a pic of is your linkage rod where it hooks to the intake bracket. IIRC it has a bolt in a slide that at the bell crank and has a flat bar to the carb stud. i would like to see just how it hooked to the bracket and make sure it has the same U shaped bellcrank piece. i thinking it should hook right to the U shaped piece and fix you right up and look stock with your carb. looks are ok but function is key to it working right to save the trans and shift properly. make sure to get a shot of your stock 2-v intake bracket where the rod hooks up also. your turn now
#1169873
02/04/12 01:19 PM
02/04/12 01:19 PM
scratchnfotraction
here is a 3 piece set up that member streetkit has in the SB for sale section and may indeed work on your car also(which would be way ez if there is enuff room to use it at the firewall and is much better sooted for 2-v to 4-v swaps) i bought this set up for a 440 truck from member streetkit,same price. if all else fails you could swap it to a 3 piece set up. what you have is a one piece set up,they dont go by how many piece are on the bracket like yours...its 1 rod or 3 rods 2 bellcranks i have all most a full set and the other rods could be made up from scratch..I have done that befroe as well.
[Re: bigdaddywiz]
#1169876
02/05/12 08:31 AM
02/05/12 08:31 AM
scratchnfotraction
now we just need to get the piece that works with the rod and hooks to the bracket i will send. it will have a bolt for the slide adjustment and hook to the bellcrank some how. this is were we need another member to step up and post a pic of the missing piece at the rod end and intake bellcrank. do you have the piece with the slide bolt from the linkage you removed from the 2-v intake set up? post a pic of the 2-v linkage if you do. maybe that piece is on the other linkage
[Re: bigdaddywiz]
#1169878
02/05/12 06:38 PM
02/05/12 06:38 PM
scratchnfotraction
ding ding ding we have the missing part just swap that piece with the bolt over to the bracket i send you,at most you would need to bolt 2 of the flat bars together. i will just send 1 flat bar and you can use that one in the pic to bolt 2 together. you can pull the whole U shaped bar/bellcrank off with the adjuster block/u-bolt/washers/hairpins when you get it bolted up and ready to measure the flat bars for correct length,you pull the rod all the way forward and hold it,close up all the adjustment in the slide and snug it down. then with it all held forward,just make the slot in the flat bar touch the throttle stud.. with the adjustment closed up,this will give max adjustment raiseing the shift points and line pressure. i think you have it now buddy i will get the bracket out in the AM for you and you will soon have it ready and working with the carb you have. post up pics as you go putting it on and adjusting the rod out. give a shout if you need help with the 2 flat bars and getting the length right
#1169879
02/06/12 01:03 AM
02/06/12 01:03 AM
bigdaddywiz
Pittsburgh, PA
cant say it enough, but THANK YOU!
you are a big help, and i really appreciate all the trouble you've gone through to help!
let me know what that shipping is and how much you want for everything!
[Re: bigdaddywiz]
#1169880
02/07/12 07:20 PM
02/07/12 07:20 PM
Posts: 5,270 Missouri
MY340
Missouri
Here's my homemade setup. Scratch gave me the linkage rod from some Mopar and I modified it with a Lowes turnbuckle using it as the adjustment. A little bit of cutting, threading and welding. Took the spring off to show it better.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
#1169882
02/13/12 02:26 AM
02/13/12 02:26 AM
bigdaddywiz
Pittsburgh, PA
ok, scratch, i got the bracket and with some imagination, i think i got it all to work! if you look close at the pics below, i had to use only the one side of the bracket that pivots with the linkage because it didnt line up. that post on the carb sticks waaay out there! its a little flimsy but it seems to work.
also, you'll notice the throttle cable is kinda crooked, but it still works.
the slotted rod wasnt long enough, so i drilled a hole in the one, and bolted a second one as an extension to be able to reach the rod on the carb. it all fits together and i really wont know how it shifts until the spring when i take the car out from winter storage.
now a quick question, is the kickdown rod supposed to move the entire range as throttle is applied? if i remember correctly, when it was stock before i installed this 340 intake/4bbl carb, it only engaged the rod when it was at or near WOT. i saw some videos on youtube of it moving the entire range, which makes sense, but i just want to make sure i got this right. it may have never been adjusted correctly?
[Re: bigdaddywiz]
#1169886
02/13/12 10:12 AM
02/13/12 10:12 AM
scratchnfotraction
looks close,yes it needs to move the whole range as the throttle moves it moves at same time,if there is any throttle movement and the TP linkage does NOT move it is misadjusted. trim the flat bar so it is out of the wat of the throttle stud and get another bolt in it so it will not pivot.it will make it more solid...just cut the slot off the one and add another bolt should fix that up. take some pliers and bent the clamp that hold the throttle cable upward some to help aline it. I have mine bent al most straight up so it it looks like it clamps from the side. you now look like its in the ballpark remember to close up the slack in the adjustment on the bell crank to the shortest setting,then make the rod to carb the length you need,that way when you drive it you can adjust the slot on the rod end to make it longer...this will make the rpm/shift points go up stretching the gears out a little trick is not to go to much as it will cause it to have a slow down shift when at light throttle..ect. some fine tunneing is needed now when you test drive it you can push it back with no binding with the carb throttle not moveing correct? you can move the throttle and linkage moves at same time/distance with no binding correct? I think you got it now
#1169888
02/13/12 11:06 AM
02/13/12 11:06 AM
bigdaddywiz
Pittsburgh, PA
as it is right now, the rod moves every bit as the throttle does.
the way i have the two flat pieces bolted together, there is only enough space for the stud to fit through, so it doesnt have the opportunity to "slide" along the stud in the opposite direction...if that makes sense. i'll get you a pic later when i get home from work.
thats a good idea, i'll heat it up and bend it up.
the way it sits now, the rod that attaches to the trans is all they way out at closed throttle...as soon as i apply throttle, it starts to move the rod, applying pressure to the trans. is that the adjustment you are referring to?
it would if i opened up the other end of that flat piece. the way i have the two flat pieces together only leaves enough room for the stud to fit through, so it moves any time the stud moves, forward and back. i suppose i could cut the front most part of the flat piece, but i didnt think that was necessary since when the throttle is closed, the rod should be moved back too, right?
#1169889
02/13/12 11:15 AM
02/13/12 11:15 AM
bigdaddywiz
Pittsburgh, PA
you need to flip the u-shaped bellcrank piece around so it is supported by both holes in the bracket.
i would if i could, but it wouldnt reach the stud when i had the bell crank u-shaped piece in the proper spot. tried it both ways. that stud is so far out to the side that this was the only way i could get it to line up. everything moves smoothly though.
you need to slide the slot in the rod to the other end of the gap you have to start with. as it is it is adjusted all the way out.
the rod is all the way out the way it is now when the throttle is closed.
may have to do some mods to it to get it to fit better,it gonna be weak with just the one end in the one hole on the bracket.
once the flat peice that goes to the stud is in place, it actually straightens things up pretty well and takes some of the slop out of not having the u shaped bell crank hooked into both holes.
maybe if i could take a quick video of it moving and send it to you somehow? maybe i'll put it on you tube...
#1169891
02/13/12 01:55 PM
02/13/12 01:55 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
you may want to bend a off set in the flat bars so you can get the bellcrank in both holes.
I agree, a nice Z bar style bend will get you there.
I have never seen a carb stud stick out that far, that is odd. Was this maybe off of a manual trans car at some point?
Another thought, can the linkage stud on the carb be turned 180, and point towards the carb? then linkage and throttle could all connect to the long side?
[Re: hp383]
#1169892
02/13/12 11:09 PM
02/13/12 11:09 PM
bigdaddywiz
Pittsburgh, PA
ok guys, i kinda went back to square one with the bracket. i got my original bracket and figured i'd try it with stacks of washers to raise it up so it clears the intake. i thought since this was the original bracket that the rod and throttle cable would mount to it no problem, which it did. the only thing that i have to do to get it functional is ream out the throttle cable clip that attaches to the carb post. thats the other thing i had to do...like hp383 suggested, i flipped the post 180* and that allowed the link to line up and the throttle cable to line up, but like i said, i just gotta ream out the throttle clip so it slides over the thicker side. scratch, i tried to align the flat part of the rod in the middle of the bellcrank like you said, but when i move the rod forward to try and adjust it in the middle and operate the throttle, it hits the bellcrank at almost WOT because i'm assuming the 4bbl has more action to it over the the 2bbl that i took off. if i move it all the way out, its fine. what will be the downside to that? here is a video of it moving: http://www.youtube.com/watch?v=sPZLC64NdWc
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#1169893
02/13/12 11:10 PM
02/13/12 11:10 PM
bigdaddywiz
Pittsburgh, PA
what i noticed scratch, after comparing the bracket you sent me and the stock bracket was the bell crank holes (where the U shaped pivot point sits) is further away from the carb and not on the flat "mount" point thats on the manifold. see how the stocker sits right on top of that...
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#1169895
02/13/12 11:12 PM
02/13/12 11:12 PM
bigdaddywiz
Pittsburgh, PA
here is a closer look at the flat piece that attaches to the bell crank and carb post so you can see what i did. will this pose any problem?
73 Road Runner
09 Challenger R/T
#1169897
02/14/12 10:21 AM
02/14/12 10:21 AM
scratchnfotraction
the 40 mile ride gave me time to think on it again,i have come up with this simple fix. take the 2 flat bars,cut the one so it does not have the slot. drill 2 holes to bolt them together,use a longer bolt with a stack of washer to make the off set and fit the back of the slot to the carb stud with the rod from trans pulled foward..(flip it back around like you had it first) that will make the flat bar long enuff,move without the throttle stud and have the off set to line it up with the carb stud and the intake bracket bell crank.. very simple and no welding you already have them bolted to gether so just spaceing them apart should work with no problems. i would go back to the taller bracket and ditch the washer on the intake bolts. close the slide up on the rod from trans up so,then make the flatbar with off set the length you need,this will aloow for adjustment on the bell crank like stock. give that a try and see what it does
[Re: bigdaddywiz]
#1169899
02/23/12 01:25 AM
02/23/12 01:25 AM
bigdaddywiz
Pittsburgh, PA
just wanted to thank everyone in the thread that helped out...especially scratch, with getting me straightened out with my kick down linkage. its all up and working. will post pics when i can. camera broke! basically just had to modify the flat rod from the carb to the bell crank and bend the tab for the throttle cable.
still havent got to drive her yet, but it appears everything will work now!
73 Road Runner
09 Challenger R/T
#1169901
02/24/12 04:30 PM
02/24/12 04:30 PM
MY340
Missouri
Make sure after you adjust your throttle linkage you should have very little/no play at the back of the rod connection/firewall with wide open throttle on the carb. I adjusted mine today as it was shifting too early out of first for my liking. Had a little too much free play and I took that freeplay out. 1st gear now shifts 5-8mph later and firmer due to the higher rpm range at light throttle. You'll get better shift points when it's properly adjusted.
