Page 3 of 3 1 2 3
Re: kickdown bracket/linkage question [Re: bigdaddywiz] #1169895
02/13/12 11:12 PM
02/13/12 11:12 PM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
here is a closer look at the flat piece that attaches to the bell crank and carb post so you can see what i did. will this pose any problem?
73 Road Runner 09 Challenger R/T
Re: kickdown bracket/linkage question [Re: bigdaddywiz] #1169896
02/14/12 08:58 AM
02/14/12 08:58 AM
scratchnfotraction Offline
with the flat bar makeing the hole stationary,IMO is not good,more chance of it hanging the throttle open,thats why it made to move independant of the throttle stud and purpose of the slot in the bar..
what i would do is build a rod with a offset in it,use a short piece of the flat bar welded to the rod end to hook to the bell crank.
then a adjustable end for the carb stud.
this will make the adjustment at the bellcrank void and you can leave it where it is not hitting and has more travel.
sorta like what MY340 did with his 3 piece set up,he just welded in the turnbuckle and made it the adjuster end.
your close.real close,i just dont like the flat bar set up and the way it locks to the throttle stud.
of corse I have had a few throttle stick Wide Open before(remeber to turn the key off when it does this)
Re: kickdown bracket/linkage question [Re: scratchnfotraction] #1169897
02/14/12 10:21 AM
02/14/12 10:21 AM
the 40 mile ride gave me time to think on it again,i have come up with this simple fix.
take the 2 flat bars,cut the one so it does not have the slot.
drill 2 holes to bolt them together,use a longer bolt with a stack of washer to make the off set and fit the back of the slot to the carb stud with the rod from trans pulled foward..(flip it back around like you had it first)
that will make the flat bar long enuff,move without the throttle stud and have the off set to line it up with the carb stud and the intake bracket bell crank..
very simple and no welding
you already have them bolted to gether so just spaceing them apart should work with no problems.
i would go back to the taller bracket and ditch the washer on the intake bolts.
close the slide up on the rod from trans up so,then make the flatbar with off set the length you need,this will aloow for adjustment on the bell crank like stock.
give that a try and see what it does
Re: kickdown bracket/linkage question [Re: scratchnfotraction] #1169898
02/14/12 11:38 AM
02/14/12 11:38 AM
Pittsburgh, PA
Pittsburgh, PA
sounds good!
i'll cut the flat piece that i have bolted together to keep from the throttle sticking (thanks for the tip!) and see what i can do with the carb post and getting the throttle cable on it.
i'll hit that tonight after work...
Re: kickdown bracket/linkage question [Re: bigdaddywiz] #1169899
02/23/12 01:25 AM
02/23/12 01:25 AM
Pittsburgh, PA
Pittsburgh, PA
just wanted to thank everyone in the thread that helped out...especially scratch, with getting me straightened out with my kick down linkage. its all up and working. will post pics when i can. camera broke! basically just had to modify the flat rod from the carb to the bell crank and bend the tab for the throttle cable.
still havent got to drive her yet, but it appears everything will work now!
Re: kickdown bracket/linkage question [Re: bigdaddywiz] #1169900
02/23/12 08:24 AM
02/23/12 08:24 AM
glad to have helped you out with it.
Re: kickdown bracket/linkage question [Re: scratchnfotraction] #1169901
02/24/12 04:30 PM
02/24/12 04:30 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Make sure after you adjust your throttle linkage you should have very little/no play at the back of the rod connection/firewall with wide open throttle on the carb. I adjusted mine today as it was shifting too early out of first for my liking. Had a little too much free play and I took that freeplay out. 1st gear now shifts 5-8mph later and firmer due to the higher rpm range at light throttle.
You'll get better shift points when it's properly adjusted.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Page 3 of 3 1 2 3
