Re: DOOR HINGE REBUILD KITS???
[Re: a493demon]
#1126825
12/03/11 09:35 PM
12/03/11 09:35 PM
Guitar Jones
I just drilled the hinges oversize and used bolts with lock nuts. But mine is a race car even though the doors are still steel.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Quicktree]
#1126827
12/03/11 09:48 PM
12/03/11 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
sounds like you may have some body flex going on.
Its not that Tony... just OLD worn out hinge bushings
[Re: rickraw]
#1126830
12/03/11 11:57 PM
12/03/11 11:57 PM
MR_P_BODY
i bought a kit at advance auto parts. worked fine. i think that snakeoil guy has greaseable hinges too. saw the add in moparmuscle. $$$. stay safe, seeya.
Does their kit have nice bronze bushings that had to be driven in.... some have little junk things that you push in with your thumb
[Re: Labratt]
#1126836
12/04/11 05:22 PM
12/04/11 05:22 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Al,to answer your COLOR question...I've decided to keep it the factory F-5 GREEN. It is a nice green,especially with gold metal flake in it! My X was 3 shades of green,with the only NICE representation of the color being the driver side rear quarter! Also,it was only a single-stage paint job...hastily done just to sell it,I'm sure! FINALLY,the GTX will get the paint job it deserves....after ALL these years!
GOOD CALL
