DOOR HINGE REBUILD KITS??? #1126822
12/03/11 08:26 PM
12/03/11 08:26 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Dropped the GTX off at my painter's shop today,and we were discussing the hinges being weak,and the door/quarter panel not lining up very well. My question to you guys is..who sells a quality pin & bushings kit..at a reasonable price, to replace the worn out originals? Also..I'd like to thank Mike Rafferty(Mr. P-Body)for taking the time to help me deliver it...and the use of his truck,as well! Thanks,Raff! Brador's
Re: DOOR HINGE REBUILD KITS??? [Re: Labratt] #1126823
12/03/11 09:00 PM
12/03/11 09:00 PM
baldwinsville new york
a493demon Online content
a493demon  Online Content
i think help has them .i have a kit from them and have not got around to doing it yet so can't tell you how well it work's.and at the moment i don't even know where it is lol . brad
Re: DOOR HINGE REBUILD KITS??? [Re: a493demon] #1126824
12/03/11 09:07 PM
12/03/11 09:07 PM
guess you will have to figure out the size of pin but here is a line. brad http://www.dormanproducts.com/gsearch.aspx?type=keyword&q=door+hinge+pin+kit
Re: DOOR HINGE REBUILD KITS??? [Re: a493demon] #1126825
12/03/11 09:35 PM
12/03/11 09:35 PM
Guitar Jones Offline
I just drilled the hinges oversize and used bolts with lock nuts. But mine is a race car even though the doors are still steel.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: DOOR HINGE REBUILD KITS??? [Re: Labratt] #1126826
12/03/11 09:45 PM
12/03/11 09:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sounds like you may have some body flex going on.
Re: DOOR HINGE REBUILD KITS??? [Re: Quicktree] #1126827
12/03/11 09:48 PM
12/03/11 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not that Tony... just OLD worn out hinge bushings
Re: DOOR HINGE REBUILD KITS??? [Re: MR_P_BODY] #1126828
12/03/11 10:12 PM
12/03/11 10:12 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
did i miss the thread where you decided on a color
Re: DOOR HINGE REBUILD KITS??? [Re: Labratt] #1126829
12/03/11 11:45 PM
12/03/11 11:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i bought a kit at advance auto parts. worked fine. i think that snakeoil guy has greaseable hinges too. saw the add in moparmuscle. $$$. stay safe, seeya.
Re: DOOR HINGE REBUILD KITS??? [Re: rickraw] #1126830
12/03/11 11:57 PM
12/03/11 11:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does their kit have nice bronze bushings that had to
be driven in.... some have little junk things that
you push in with your thumb
Re: DOOR HINGE REBUILD KITS??? [Re: MR_P_BODY] #1126831
12/04/11 02:04 AM
12/04/11 02:04 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
my hinges were already rebushed when i got my car mr.p. i used thread locker & pressed them in. alot depends if the hole is oblonged. their bushings are bronze. stay safe, seeya.
Re: DOOR HINGE REBUILD KITS??? [Re: rickraw] #1126832
12/04/11 08:18 AM
12/04/11 08:18 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
NAPA carries a variety:
http://www.napaonline.com/Catalog/Result...mp;Dp=3&N=0
You just need to know what length and diameter you need.
Re: DOOR HINGE REBUILD KITS??? [Re: TooMany62s] #1126833
12/04/11 09:58 AM
12/04/11 09:58 AM
BDW Offline
BDW  Offline
PN 38382
Re: DOOR HINGE REBUILD KITS??? [Re: BDW] #1126834
12/04/11 02:00 PM
12/04/11 02:00 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Wilson! I'll have to check the HELP section out at Advance or O'Reilly's out this week! BTW..looking at that rust-encrusted hinge that Dave Young's installing new bushings in..wouldn't you think he would have at least sand-blasted and painted them? Just sayin'!
Re: DOOR HINGE REBUILD KITS??? [Re: bonefish] #1126835
12/04/11 02:19 PM
12/04/11 02:19 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Al,to answer your COLOR question...I've decided to keep it the factory F-5 GREEN. It is a nice green,especially with gold metal flake in it! My X was 3 shades of green,with the only NICE representation of the color being the driver side rear quarter! Also,it was only a single-stage paint job...hastily done just to sell it,I'm sure! FINALLY,the GTX will get the paint job it deserves....after ALL these years!
Re: DOOR HINGE REBUILD KITS??? [Re: Labratt] #1126836
12/04/11 05:22 PM
12/04/11 05:22 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
GOOD CALL
Re: DOOR HINGE REBUILD KITS??? [Re: bonefish] #1126837
12/04/11 06:37 PM
12/04/11 06:37 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Al! BTW...you can see my GTX in action on You Tube..at Randy B's 440 GTX. There's 3-4 videos from the track on there. Take care! Randy
Re: DOOR HINGE REBUILD KITS??? [Re: Labratt] #1126838
12/04/11 10:18 PM
12/04/11 10:18 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
We`ve sold tons of these kits with no complaints.
http://pepsparts.com/proddetail.asp?prod=280004
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
