Re: DOOR HINGE REBUILD KITS???
[Re: a493demon]
#1126825
12/03/11 09:35 PM
12/03/11 09:35 PM
Guitar Jones
I just drilled the hinges oversize and used bolts with lock nuts. But mine is a race car even though the doors are still steel.
[Re: Quicktree]
#1126827
12/03/11 09:48 PM
12/03/11 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
sounds like you may have some body flex going on.
Its not that Tony... just OLD worn out hinge bushings
[Re: rickraw]
#1126830
12/03/11 11:57 PM
12/03/11 11:57 PM
MR_P_BODY
i bought a kit at advance auto parts. worked fine. i think that snakeoil guy has greaseable hinges too. saw the add in moparmuscle. $$$. stay safe, seeya.
Does their kit have nice bronze bushings that had to be driven in.... some have little junk things that you push in with your thumb
[Re: Labratt]
#1126836
12/04/11 05:22 PM
12/04/11 05:22 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Al,to answer your COLOR question...I've decided to keep it the factory F-5 GREEN. It is a nice green,especially with gold metal flake in it! My X was 3 shades of green,with the only NICE representation of the color being the driver side rear quarter! Also,it was only a single-stage paint job...hastily done just to sell it,I'm sure! FINALLY,the GTX will get the paint job it deserves....after ALL these years!
GOOD CALL
