Let's see your homemade floor jack transmission cradles #1110884
11/10/11 02:56 PM
11/10/11 02:56 PM
Dexter, Michigan
copper67440 Offline OP
mopar addict
mopar addict
Dexter, Michigan
I dug mine out and thought that there has to be alot of them out there. Let's see them maybe I can improve mine.
Re: Let's see your homemade floor jack transmission cradles [Re: copper67440] #1110885
11/10/11 03:00 PM
11/10/11 03:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I just made a flat plate that drops into the saddle hole that is the size of the trans pan with a piece of angle on 3 sides to keep it from sliding off, works for now.
I'm going to try to score a used motorcycle jack to make my next one since I can't get the trans out from under the car on the jack .
Re: Let's see your homemade floor jack transmission cradles [Re: JohnRR] #1110886
11/10/11 09:28 PM
11/10/11 09:28 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I bought one a long time ago that works the same way, its basicaly a flat piece of steel with 3 sides a couple inches high and a post on the bottom to go into the floor jack hole. Its definetly a life/time saver, I think it might be made by TCI.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Let's see your homemade floor jack transmission cradles [Re: JohnRR] #1110887
11/10/11 10:35 PM
11/10/11 10:35 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Same thing I fabbed only I added a pair of 2" velcro straps to keep the trans from moving off the jack until I wanted it to. Works great for using up some scrap.
Old, tired, and sometimes broke down. Me, not my car...
Re: Let's see your homemade floor jack transmission cradles [Re: Shoozy] #1110888
11/10/11 11:12 PM
11/10/11 11:12 PM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
I dont have a picture of it but, I used a flat piece of steel with a pin welded to it on the bottom. On the top I welded a 3 foor section if 3/16x 2-1/2 angle iron about 36 inches long. lay a thick rag on it and set a door on it and one man can install a door. Made one for my son to use in the body shop..
duh, I re-read the post and saw it says TRANSMISSION... oh well
