Re: Let's see your homemade floor jack transmission cradles
[Re: JohnRR]
#1110886
11/10/11 09:28 PM
11/10/11 09:28 PM
Posts: 4,976 new jersey usa
11secdart
new jersey usa
I bought one a long time ago that works the same way, its basicaly a flat piece of steel with 3 sides a couple inches high and a post on the bottom to go into the floor jack hole. Its definetly a life/time saver, I think it might be made by TCI.
[Re: Shoozy]
#1110888
11/10/11 11:12 PM
11/10/11 11:12 PM
Posts: 738 Columbus Ohio
mopfried
Columbus Ohio
I dont have a picture of it but, I used a flat piece of steel with a pin welded to it on the bottom. On the top I welded a 3 foor section if 3/16x 2-1/2 angle iron about 36 inches long. lay a thick rag on it and set a door on it and one man can install a door. Made one for my son to use in the body shop..
duh, I re-read the post and saw it says TRANSMISSION... oh well
