727 transmission case questions #1065093
08/29/11 02:19 PM
08/29/11 02:19 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I have a LOCK-UP 727 from a '78 400. Can this case be used with NON-LOCKUP internals (from a '74 318 truck 727) for a race transmission, behind a 440? What parts are interchangeable from lock up to non lockup?
I have a TA manual valve body and a TA converter, what else is needed? Also have many kick down lever ratios to choose from.
Thanks,
Brian Dunnigan
Re: 727 transmission case questions [Re: '72CudaRacer] #1065094
08/29/11 02:47 PM
08/29/11 02:47 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I used a case from a lock up 904 for a non lock up before. The difference in lock up vs non in either is the front input shaft has an oiling hole in it, the front guts, front pump I think, and valve body.
I cant tell ya for sure which parts are different, but its internals basically.
The 904 I changed out is still alive, and I dont recall changing or blocking any fluid passages.
Kasey
Re: 727 transmission case questions [Re: '72CudaRacer] #1065095
08/29/11 03:09 PM
08/29/11 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I changed my 518 lock up with OD to a standard 727
but with OD... its the input shaft... the lock up
one has a hole down through the center to pass oil
through it... the non lock up doesnt have the hole
John Cope set me up with the parts... I also changed
the whole front pump(wasnt sure if the pump drive lugs
would fit and standard converter)
Re: 727 transmission case questions [Re: MR_P_BODY] #1065096
08/29/11 05:55 PM
08/29/11 05:55 PM
NC
440Jim Offline
440Jim  Offline
NC
The only thing I can add, is that along with the input shaft, you need to swap the reaction support since the passages are different. This is the part that covers the pump gears on the inside of the transmission.
See the attached pic
Re: 727 transmission case questions [Re: 440Jim] #1065097
08/29/11 06:07 PM
08/29/11 06:07 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Yes you can use the case for a race non lockup , but no you cannot use it behind a 440 if it came from a 318 !
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: 727 transmission case questions [Re: 65dragnet] #1065098
08/29/11 06:10 PM
08/29/11 06:10 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
My bad I just read your post again you said internals from a 727 sb Sorry ! YES U CAN LOL
Re: 727 transmission case questions [Re: 440Jim] #1065099
08/29/11 07:54 PM
08/29/11 07:54 PM
Guitar Jones Offline
The reaction shafts are the same EXCEPT for that third ball. It can be removed though with a pointed carbide burr and a bent tipped punch. If I can do it, you can too. A 904 is the same too, remove the ball and you have a late, two ring input shaft reaction shaft. If you don't remove it though you'll end up with a blue torque converter.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 727 transmission case questions [Re: Guitar Jones] #1065100
08/30/11 07:33 PM
08/30/11 07:33 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Curious, which 727 only used one ball and one open hole??
Re: 727 transmission case questions [Re: PolyDart] #1065101
08/30/11 07:40 PM
08/30/11 07:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All 727's prior to '78 had only one ball and one hole.
Re: 727 transmission case questions [Re: John_Kunkel] #1065102
08/30/11 08:07 PM
08/30/11 08:07 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
