Re: 727 transmission case questions
[Re: '72CudaRacer]
#1065095
08/29/11 03:09 PM
08/29/11 03:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I changed my 518 lock up with OD to a standard 727 but with OD... its the input shaft... the lock up one has a hole down through the center to pass oil through it... the non lock up doesnt have the hole John Cope set me up with the parts... I also changed the whole front pump(wasnt sure if the pump drive lugs would fit and standard converter)
[Re: 440Jim]
#1065099
08/29/11 07:54 PM
08/29/11 07:54 PM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
The only thing I can add, is that along with the input shaft, you need to swap the reaction support since the passages are different. This is the part that covers the pump gears on the inside of the transmission.
See the attached pic
The reaction shafts are the same EXCEPT for that third ball. It can be removed though with a pointed carbide burr and a bent tipped punch. If I can do it, you can too. A 904 is the same too, remove the ball and you have a late, two ring input shaft reaction shaft. If you don't remove it though you'll end up with a blue torque converter.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: PolyDart]
#1065101
08/30/11 07:40 PM
08/30/11 07:40 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All 727's prior to '78 had only one ball and one hole.
