Re: engine and tranny install [Re: POS Dakota] #1053264
08/16/11 12:49 PM
08/16/11 12:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
So...about those carb lift plates...I look at them and I just think it would really suck to drop a motor and trans if it pulled out on ya.
Are they really that strong? Can I trust it?
I've never tried one, but i think I am going to have to this time around since I will be doing it all myself.
I have used that plate on many different motors, like 15-20 motors with never a failure. As long as the the studs are bottemed in the manifold, they won't fail. Failure can occur if someone uses bolts that are not bottomed in the threads.
It's the handiest most compact way to do it, way better than those cheap tilters sold by HF.
I have lifted International truck 392 and 404 gas engines which are much bigger than a 440.
gETTING MY MONnIES WORTH OUT of that lift plate(it was free)
Re: engine and tranny install [Re: dOc !] #1053265
08/16/11 12:52 PM
08/16/11 12:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
This guy here appears to be a first-timer...
lots of the cheapO cranes being tippy....
And AGAIN .. him being a newbie.
Then there's no better way to learn, then, is there.
No coddling around here.
You throw them into the deep end of the pool.
They learn to swim REAL FAST.
GOIN' Commando .... a DOUBLE ...at choo' !
The prob is ... is that if the M/T combo gets-away from the OP ... it can damage the car SEVERELY ...or he can damage HISself !
same thing will happen if he drops just the engine or just the tranny.
It would be assaine to do it separately.
Re: engine and tranny install [Re: dOc !] #1053266
08/16/11 02:41 PM
08/16/11 02:41 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I am not a FAN of plates with alum intake manifolds. I have seen one pull-through the threads and badly damage the pan ...and have heard of others.
This is what I am deathly afraid of happening.
I guess I can thread a bolt into the front and back of each head and use a 4 way chain...I always looked at those lift plates and felt funny.
Re: engine and tranny install [Re: Challenger 1] #1053267
08/16/11 02:43 PM
08/16/11 02:43 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I am only lifting an iron headed smallblock....but the intake is aluminum...I take it I should get some grade 8s instead of using the normal carb studs if I do try this.
Re: engine and tranny install [Re: POS Dakota] #1053268
08/16/11 02:49 PM
08/16/11 02:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
I always used the studs that were in the manifold even with iron heads, no grade 8 needed.
Re: engine and tranny install [Re: Challenger 1] #1053269
08/16/11 02:57 PM
08/16/11 02:57 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Chally_1 .... YOU of all people .. the 1 that appears to have two diff cranes/hoists ....one a ChinaMart and the other being a BlueBird
To even suggest that a first-timer would have the same probs or luck with doing an install both ways ? ....
A triple ..at choo' ! ..
Re: engine and tranny install [Re: POS Dakota] #1053270
08/16/11 03:04 PM
08/16/11 03:04 PM
Florida STAYcation
Florida STAYcation
NEVER heard of a carb-studs breaking using a plate .... just saw the one pull-out what remained of the threads in the alum intake. I did not actually eyeball the actual failure in-progress ... but from what my Bud saw was the one fail ...and that failed the other one on that end ...THEN the other two went. It was lucky the engine was only a foot or so off the ground.
Re: engine and tranny install [Re: buildanother] #1053271
08/16/11 04:11 PM
08/16/11 04:11 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
You can place trans up in there first, put crossmember in and trans mount, and can leave floor jack under it until eng is dropped in. Have done it a few times.
I've done it like this and can then use a carb flange plate to install the engine without taking the hood off (worst part of the whole job), and I can do it all without help.
Re: engine and tranny install [Re: Drip] #1053272
08/16/11 10:06 PM
08/16/11 10:06 PM
AndyF Offline
AndyF  Offline
Pull the hood and then slide the engine and trans together into the car. An overhead crane makes the job a snap! With the crane it usually only takes a few minutes to slide an engine in or out.
Re: engine and tranny install [Re: AndyF] #1053273
08/17/11 09:19 AM
08/17/11 09:19 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
get one of these,worth its weight in gold
Re: engine and tranny install [Re: bonefish] #1053274
08/17/11 10:35 AM
08/17/11 10:35 AM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
Another idea that I use is jack up and block the rear of the car. Then remove the front wheels and lower the front. It gives you even more of a angle for the engine/trans to slide in.
Re: engine and tranny install [Re: bonefish] #1053275
08/17/11 12:01 PM
08/17/11 12:01 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Where and how muchos?
Re: engine and tranny install [Re: POS Dakota] #1053276
08/17/11 12:26 PM
08/17/11 12:26 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Where and how muchos? [/quote the info is in the pic.on the tool.
Re: engine and tranny install [Re: bonefish] #1053277
08/17/11 12:39 PM
08/17/11 12:39 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have one of those swivel plates and it works great.
So long as the threads in the intake are in good shape you shouldn't have a problem. If your intake is a half stripped out swap meet special then maybe use one of the chain setups instead.
Also you don't need to overtighten the studs or bolts if you use the intake plate. There is no way those can turn out once a load is put on them. I've seen guys lean on those like they are lug nuts and it's just not necessary. Hand snug is perfect.
Re: engine and tranny install [Re: Neil] #1053278
08/21/11 10:50 PM
08/21/11 10:50 PM
California
Drip Offline OP
Drip  Offline OP
California
Thanks for all the help. Put it in with motor and tranny as a unit from the top. used the intake plate. Was accually pretty easy. Did it by myself. thanks again.
Re: engine and tranny install [Re: Drip] #1053279
08/21/11 11:17 PM
08/21/11 11:17 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
And you still have both arms and legs... I'm shocked!
Nice job and good to read you got it installed.
Re: engine and tranny install [Re: dOc !] #1053280
08/21/11 11:26 PM
08/21/11 11:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Probably simpler putting the trans in the car first(attaching it to the trans X-member then blocking the front of the trans up) ... THAN trying to put it in as a combo.... ESPECIALLY if this is your first time.
That's the way I do it. No problem.
I have mechanical Aptitude.
I can screw up anything.
Re: engine and tranny install [Re: bboogieart] #1053281
08/27/11 01:14 AM
08/27/11 01:14 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
engine/trans with tilter.....
Re: engine and tranny install [Re: Drip] #1053282
08/27/11 10:15 AM
08/27/11 10:15 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
*** Install as a pair.
Prior to installing jack up the rear of the car. It is not absolutely necessary (as you can see by all the people here who do not do it) however, it makes the one peice install so much easier. It effectively makes the opening bigger to work with because it is at less of an angle. Jack the rear of the car as high as you can and install the unit. This is the easiest way and does not require a load leveler (although one does help). It also is the safest way to do it as it slightly lowers the front end and prevents your rad support from getting scrapped up. Just guide in the tail shaft and once under the cowl, just "slowly" lower the unit while moving forward at the same time. It should drop right in place. Then lower car and raise tailhouseing into place if necessary.
