Page 1 of 3 1 2 3
How Fast with Indy EZ heads? #1052436
08/14/11 01:34 AM
08/14/11 01:34 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Just curious how fast you guys are going with them. I am running a set on my engine builders Duster, and so far the pump gas motor has pushed it to 10.40's and almost into the 10.30's, just curious how fast you can go. These are unported and so far, not being a wedge guy, I am impressed on how hard the car leaves. It carried the front wheels this week +30' at about 10" off the ground.....
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052437
08/14/11 03:19 AM
08/14/11 03:19 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
6.22 at 101 in 1/8 full exhaust, pump gas at 3500+
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052438
08/14/11 07:19 AM
08/14/11 07:19 AM
mohnton pa
rva Offline
super gas
rva  Offline
super gas
mohnton pa
9.99 at 134 mph cnc ported
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052439
08/14/11 07:55 AM
08/14/11 07:55 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
I,AM WORKING ON A 1973 PRO STREET DUSTER WITH A 440 O30 SIX PISTONS STEEL CRANK . A 590 CAM OR A 625 ROLLER. WHAT INTAKE IS THE BEST FOR THE EZ-1 HEADS A MAX WEDGE OR US A SINGLE FOUR?
Re: How Fast with Indy EZ heads? [Re: mosweethemi] #1052440
08/14/11 08:45 AM
08/14/11 08:45 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
440-2 indy- second thought with those pistons, lower RPM, dual plane single from indy, not sure of the numbers. I'm sure there are other good dual planes to use.
Re: How Fast with Indy EZ heads? [Re: Dodgeguy101] #1052441
08/14/11 09:04 AM
08/14/11 09:04 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hey the piston or speed pro L2355 030 , read end 456 , tire or quick time 18/5 -31 two 625 on the max wedge intake should work you think with eather cam 590 or 625 roller .I have the max wedge intake and would have to buy the Indy one. Trying to save me some money .Thats all
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052442
08/14/11 11:57 AM
08/14/11 11:57 AM
Dragula Offline OP
Dragula  Offline OP
Wow 6.22 in the 1/8th....But mph is low at only 101?
We ran 6.61 last week at over 102mph. I have to look and see, but I am pretty sure we had one time slip at 103mph, but our gearing is for 1/4 racing. I am impressed so far, and I am sure 6.50's are just a couple hundred rpm higher on the launch, but I leave nice and easy on it while we dial in the 4-link. I had to actually abort one run as we got the shock damping too tight, but we made some nice progress on the next couple of passes. So far the best 60ft has been a 1.465s...
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052443
08/14/11 12:01 PM
08/14/11 12:01 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I went 6.80 @ 101 in the heat in my chally at 3850lbs on 93 pump gas only time out with combo.
they were the CNC EZ's with a 308 port volume done by jeff at MCH on here!
Mopar Performance
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052444
08/14/11 12:02 PM
08/14/11 12:02 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
111 Sorry. that was in my Challenger. the engine is now in the cuda below. gen 3 hemi goin in the challenger. my 60fts were right around 1.35
Re: How Fast with Indy EZ heads? [Re: mosweethemi] #1052445
08/14/11 01:01 PM
08/14/11 01:01 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Are you talking about a factory max wedge intake or one of the indy intakes? The factory maxi intakes are 70+ HP down on a good single plane.
Getting old just means you were smarter than some and luckier than others.
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052446
08/14/11 11:58 PM
08/14/11 11:58 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
New motor this weekend, 440 block, 440 Source 523" stroker, With the INDY EZ heads...time trials today #1 6.200 #2 6.206 #3 6.198 this is 1/8th mile, with a 3360 lb car with driver in it. The DA was at 1500 plus or minus all day
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052447
08/15/11 12:36 AM
08/15/11 12:36 AM
AndyF Offline
AndyF  Offline
Just depends on how well your car hooks and how much it weighs. My current motor is making about 850 hp with EZ heads so that is enough power to run 8's in a well sorted out door slammer. In a rail it would go even faster.
Re: How Fast with Indy EZ heads? [Re: AndyF] #1052448
08/15/11 12:59 AM
08/15/11 12:59 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Gone 9.40s in my 3200lb coronet w/ 496" RB, MW EZs done by porter and Fliying toilet...
Taking over the World one win light at a time.
Re: How Fast with Indy EZ heads? [Re: dannysbee] #1052449
08/15/11 08:37 AM
08/15/11 08:37 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Why would the max wedge be down on HP ?over a single four?stock 426 max wedge was at 415 or 426 HP This is a good 440 with good pistons and good cam 590-625 roller .The EZ-1 heads would not keep the HP around 425 ?or more ?
Re: How Fast with Indy EZ heads? [Re: mosweethemi] #1052450
08/15/11 10:18 AM
08/15/11 10:18 AM
tboomer Online work
tboomer  Online Work
Good thread here.. I will be watching this as I want new heads later this year..
Re: How Fast with Indy EZ heads? [Re: mosweethemi] #1052451
08/15/11 10:21 AM
08/15/11 10:21 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
That manifold is a restriction, if nothing has been done to it. The newer single plane intakes will outflow them. I know they are great for the cool factor, but for performance they are down. Read AndyF's book, he did back to back dyno tests, down 80HP.
Re: How Fast with Indy EZ heads? [Re: Dodgeguy101] #1052452
08/15/11 10:40 AM
08/15/11 10:40 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
It's not that the cross ram will not make any HP just not as much as a good single plane. Sell the cross ram to someone that needs it for a nostalgia super stock if its modified or to someone doing a restoration if is unmodified. The cross ram intake will bring enough to buy a good single plane and a new carburetor.
Re: How Fast with Indy EZ heads? [Re: mosweethemi] #1052453
08/15/11 09:11 PM
08/15/11 09:11 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I'm not a big fan of using six pack pistons in a engine with big heads and big cam. Too heavy.
Re: How Fast with Indy EZ heads? [Re: forphorty] #1052454
08/16/11 07:53 AM
08/16/11 07:53 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
As i found out to my cost, my old 440, stock 6 pack rods, 6 pack pistons, ported iron heads, then later edelbrocks, Crane R280 Roller. Revved it to 7000 trying to get in the 10's, spun a bearing and a rod exited the sump.
New 440, smaller flat tappet cam, better recriprocating assembly, more comp, old heads int and carb, time in sig and i think there's maybe a 10.1 in the car, shift at 6200 trap at 6500.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: How Fast with Indy EZ heads? [Re: deaks] #1052455
08/16/11 11:28 AM
08/16/11 11:28 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
5.95@114 at 3300lbs footbraking with a 499" on race gas. They are the EZ-1's cnc ported by Modern. The cam is to small for the motor but seems to work well. The car is at the chassis shop now getting a backhalf done to it then I can up the cam and switch to e-85.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Page 1 of 3 1 2 3
