Re: How Fast with Indy EZ heads?
[Re: Dragula]
#1052437
08/14/11 03:19 AM
08/14/11 03:19 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
6.22 at 101 in 1/8 full exhaust, pump gas at 3500+
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: mosweethemi]
#1052440
08/14/11 08:45 AM
08/14/11 08:45 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
440-2 indy- second thought with those pistons, lower RPM, dual plane single from indy, not sure of the numbers. I'm sure there are other good dual planes to use.
[Re: sixpackgut]
#1052442
08/14/11 11:57 AM
08/14/11 11:57 AM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
Wow 6.22 in the 1/8th....But mph is low at only 101?
We ran 6.61 last week at over 102mph. I have to look and see, but I am pretty sure we had one time slip at 103mph, but our gearing is for 1/4 racing. I am impressed so far, and I am sure 6.50's are just a couple hundred rpm higher on the launch, but I leave nice and easy on it while we dial in the 4-link. I had to actually abort one run as we got the shock damping too tight, but we made some nice progress on the next couple of passes. So far the best 60ft has been a 1.465s...
[Re: Dragula]
#1052443
08/14/11 12:01 PM
08/14/11 12:01 PM
Posts: 6,295 U.S.
moparniac
U.S.
I went 6.80 @ 101 in the heat in my chally at 3850lbs on 93 pump gas only time out with combo.
they were the CNC EZ's with a 308 port volume done by jeff at MCH on here!
Mopar Performance
[Re: Dragula]
#1052444
08/14/11 12:02 PM
08/14/11 12:02 PM
sixpackgut
Charleston
111 Sorry. that was in my Challenger. the engine is now in the cuda below. gen 3 hemi goin in the challenger. my 60fts were right around 1.35
[Re: AndyF]
#1052448
08/15/11 12:59 AM
08/15/11 12:59 AM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
Gone 9.40s in my 3200lb coronet w/ 496" RB, MW EZs done by porter and Fliying toilet...
Taking over the World one win light at a time.
[Re: mosweethemi]
#1052451
08/15/11 10:21 AM
08/15/11 10:21 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Why would the max wedge be down on HP ?over a single four?stock 426 max wedge was at 415 or 426 HP This is a good 440 with good pistons and good cam 590-625 roller .The EZ-1 heads would not keep the HP around 425 ?or more ?
That manifold is a restriction, if nothing has been done to it. The newer single plane intakes will outflow them. I know they are great for the cool factor, but for performance they are down. Read AndyF's book, he did back to back dyno tests, down 80HP.
[Re: mosweethemi]
#1052453
08/15/11 09:11 PM
08/15/11 09:11 PM
Posts: 1,457 oklahoma
forphorty
oklahoma
Hey the piston or speed pro L2355 030 , read end 456 , tire or quick time 18/5 -31 two 625 on the max wedge intake should work you think with eather cam 590 or 625 roller .I have the max wedge intake and would have to buy the Indy one. Trying to save me some money .Thats all
I'm not a big fan of using six pack pistons in a engine with big heads and big cam. Too heavy.
[Re: forphorty]
#1052454
08/16/11 07:53 AM
08/16/11 07:53 AM
Posts: 3,210 robin hood country
deaks
robin hood country
As i found out to my cost, my old 440, stock 6 pack rods, 6 pack pistons, ported iron heads, then later edelbrocks, Crane R280 Roller. Revved it to 7000 trying to get in the 10's, spun a bearing and a rod exited the sump. New 440, smaller flat tappet cam, better recriprocating assembly, more comp, old heads int and carb, time in sig and i think there's maybe a 10.1 in the car, shift at 6200 trap at 6500. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1052455
08/16/11 11:28 AM
08/16/11 11:28 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
5.95@114 at 3300lbs footbraking with a 499" on race gas. They are the EZ-1's cnc ported by Modern. The cam is to small for the motor but seems to work well. The car is at the chassis shop now getting a backhalf done to it then I can up the cam and switch to e-85.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
